Reset Charge Station Pro?
wautard1
Eric
Seattle
23 Lightning Lariat
Does anyone know how to reset a Charge Station Pro? I wasn’t able to set up Wi-Fi the first time around and now I can’t get the Wi-Fi net work to start again. I’ve even tried the factory reset button on the inside and can’t figure it out.
BzzzzztZapPow
21 Explorer Hybrid, 18 Fusion Hybrid, 22 Lightning
Take off the cover....there is a little reset button on the top left. Hold until the light turns white. Bang head against wall trying to get the wifi connected.
Below is my post from some time ago with the directions. Sadly, I have to do this more often than I would like.
https://www.f150lightningforum.com/...-ford-pass-connection-issue.11219/post-234082
smandel
Steven
Las Cruces, NM
2022 lightning Lariat
Retired Stagehand/ Electric/Sound/Props/Carp/Etc
Power it down by turning breaker off for a minute if the hard reset button doesn’t work. If you still can’t reset then try customer care. They might have an idea or ship you a new one.
RedLightning86
Wisconsin Dells
It took me about a dozen tries to get it to connect. I actually unplugged the wifi repeater about 4 feet away, left my kitchen door open, and after a few more tries, it connected. Annoying, but if it stays connected, is bearable. If has to be done a lot, then I'll sell it on e-Bay and get a different brand, since others are coming out, and with easier 2-way birectional at that!
Henry Ford
I only got WiFi set up when I temporarily disabled the 5 ghz network. I think most routers have an automatic way of doing this. Mine was in the troubleshooting section of the router's app.
This may or may not be the problem but I thought it worth mentioning.
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
Sorry to bring up an old topic, has anyone run into the issue of the factory reset button not doing anything? I’ve held it a solid minute and the lights stay blue.
Folks have mentioned this "problem" in a couple of threads with recent activity, IIRC someone was able to get it to reset with a prolonged pressing of the button, and another was able to convince Siemans that there is a problem and Ford might be approving a warranty replacement.
FCSP won't factory reset or connect to wifi/bt | Ford Lightning Forum For F-150 Lightning EV Pickup: News, Owners, Discussions, Community (f150lightningforum.com)
