Tesla Magic dock adaptor slower?
ronscantlin
Ron
Orlando, fl
2022 f150 platinum
I FINALLY figured out how to get the stinking Tesla magic dock to release from the charger and tried it out. Well, while I’m impressed with the convenience, I’m unimpressed by the speed. 106kw vs the 160-190kw when using my a2z. I’ve only used the magic dock once so far, so……..
What’s everyone’s experience and/or comparisons using the magic dock vs your own adapter?
El Duderino
2025 Flash Job 1
I can't get the damn thing out so I always use A2Z adapter. But only tried twice at same Supercharger location.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I have used one at the same location several times the last two summers. When the adaptor comes out with my first attempt I use it, when it refuses, I use my own adapter. Speed was just the same with or without it at the Boardman Sage Center location.
3rd rock
Automotive Technician
I have the one that came with the truck, only used it once and the dcfc was derated that day due to the summer heat so best I got was 73kWh or some low weird number like that.
Your SOC% was higher...
ronscantlin
ronscantlin
Ron
Orlando, fl
2022 f150 platinum
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Tesla changed the logic/procedure on the V3/V4 Magic docs. You've got to push the button on the NACS plug, wait for the click, and then push the NACS/CCS adapter up into the unit and then pull it out. I too fought with this over the last two years, and saw the proper procedure on a UTube video last summer. Haven't had a problem since. I recently saw 189kw speed for 10 minutes with the truck at 45%SOC & temp in the 50's dF
abcut973
Anthony
Denham Springs
2022 F150 Lightning Platinum, 2020 BMW X7 xDrive40i, 2019 Mercedes C300 cab
Yes the procedure changed to get it out as mentioned above. But you have to check supercharger.info to see which locations are actually releasing the magic docks. Some v3/v4s have it but Tesla has not unlocked those yet.
I used the magic dock at the Lordsburg location this past winter. First attempts took several tries until I realized I wasn't holding the button long enough. Second time I used it, had no problem. Both times, ~40% SOC beginning, I had very good charge rates. I think I averaged 130kW over 25min.
stgrace
Shaun
Atlanta
2024 Ford Lightning
Construction
I have never got the magic dock to work.
potato
BC, Canada
2023 F150 Lightning XLT ER
Everybody needs an OBD dongle + CarScanner or equivalent, to monitor
1) Max amps the charger says it can supply
2) Amps requested by the truck
3) Amps supplied
Then you can determine if it's the truck or the charger who limits the charge rate.
3) Amps supplied
Or the adapter is restricting.
ronscantlin
ronscantlin
Ron
Orlando, fl
2022 f150 platinum
This.
I hooked up the forscan and read the codes. There was a derate thermal code for the coupler for that time stamp, so it could have been either the Tesla evse or the truck requesting derates. I can’t tell by the code, but it’s clear it was for that event. I hit those chargers often, so I’ll report back.
potato
BC, Canada
This.
The adapter is passive. It doesn't communicate with the truck. If your charge port was heating up enough to set a code, that is a little concerning. I wonder how hot the adapter was.
