sunrise089
- Aug 12, 2024
- Central Florida
- Jeep Gladiator
Hi! I'm a 'car guy' and a 'tech guy' but have preferred to keep those interests separate and drive low-tech simple vehicles. My current truck is a Jeep Gladiator with a manual transmission. I love my truck but I am considering replacing it with a Lightning because: a) I drive nearly 2,500 miles/month and 17mpg is crushing me; b) I'll benefit from the greater capabilities of a half-ton truck; and c) the Gladiator has only marginal on-road performance with the stick plus 35" tires and it would be nice to gain some passing power.
I've read enough to know most of the obvious red flags don't apply to me: I can charge at home; I have access to an ICE vehicle for any infrequent log trips; I'm in Florida so cold weather isn't an issue, etc. I do have a few questions about my use case and my economic calculus which I'd love peoples' perspective on:
Main question: My family is in the beef cattle business, so while I won't be doing any hard-core rock crawling or mudding, the truck will be used as a truck. My 'truck' usage includes using the bed ~150 days each year (with ~20 days carrying 1,000+lbs); towing a trailer ~50 days each year mostly in the 3,000lbs-5,000lbs range; driving down dirt/gravel roads ~200 days each year; and driving through fields and pastures ~100 days each year. While I'm sure the Lightning will handle the payload and tow weight better than my Gladiator, the offroad use concerns me, especially given I plan to level/lift the truck to gain much needed ground clearance but possibly at the cost of suspension travel(?). I'm not driving like an idiot but I also don't have time to baby the truck offroad - will the Lightning's suspension perform well enough and hold up under that sort of usage? If it matters I'm currently leaning towards a used Lariat ER and adding the Rough Country 3" lift.
Small question: As I said my current truck gets 17mpg. From what I've read a Lightning will get around 2.0miles/kwh, and a lifted Lightning with bigger tires will get around 1.7miles. When comparing costs do I also need to factor in charging losses or do the 2.0/1.7 figures already factor that in? FYI my electricity cost is $.111/kwh and I expect 100% of my charging to be at home so my math has me saving about $4k/year on fuel.
Small question: I won't consider any SR trucks without the tow package, but I'm unsure how much to prioritize the tow package on an ER. I probably won't ever tow more than 7,700lbs but the additional cooling has a lot of appeal as I'll be towing lower weights fairly frequently in a warm climate. Is there a consensus on the package's value at lower towing weights?
Small question: Has anyone carried a round hay bale in their bed? The bed will handle the weight easily but I'm unsure about the tailgate. In my Gladiator I use a small trailer but carrying the bale in the bed is a big potential advantage in upgrading to a half-ton.
Small question: I'd like to run 34"-35" tires because I need the ground clearance. I'd love to do Raptor take-offs but I'm not comfortable using a spacer, so I assume my best bet is stock XLT 18" rims. Any recommendations for tires? I'd love a mud terrain but I suspect that will hurt efficiency even more so hopefully there is an A/S or A/T tire which is reasonably efficient while still working well offroad. I can also post this in the tires/wheels subforum but figured I'd include it here too.
Thank you for any and all thoughts and advice!
