theblunden
NC
2023 F150 Lightning XLT
I thought about my unscheduled XLT ???
I charged up my Lightning today after Sunday's road trip, I had to wait until today, unfortunately weekends and federal holidays are considered peak demand here so I had to wait until today to earn credits.
Before I plugged in this morning my garage meter read 190KWH
The lighting had a SOC of 31%, charging began at 6:08 am
Charging ended at a SOC of 95%, which was the level at the start of Sundays trip.
The Ford Pass logs indicated that 83 kWh were loaded to the battery
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665538523856
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665538552788
The electric meter showed it took 94 kWh to the FCSP and the trucks charger.
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665539934546
Interestingly the FCSP was very accurate measuring actual energy to the truck
That shows 11 kWh of conversion losses or around 11.3%
Costs 94 x 0.253 = 23.78
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665539780766
National Grid TOU credits accounted for only 62 kWh at 0.03 for $1.86
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665539651151
Net energy cost $23.78 - $1.86 = $21.92
Miles traveled 177, yielding 12.4 cents a mile
Or a 15MPG value comparison to my former truck $1.86 a gallon break even value
Today diesel is priced at 4.899 / gal, at that rate in my old truck the trip would have cost $57.81
Savings of $35.89
We will be repeating this trip on Thanksgiving, with cooler weather I'm curious how much more energy we will consume!!
gsquirrel02
Andre
Hampton Roads, Virginia
2022 Lightning Lariat ER, 2020 Pathfinder
<snip>
Center speaker grill is warped
<snip>
WHAT?? On a vehicle that's not even a year old? Oh heck no - they'd have to fix that for me.
Not to mention the subpar audio system - but that's a different topic.
kab
Carroll County, MD
12.5 hours after taking delivery of my truck, I dropped it off at LineX for a premium spray in bedliner this morning. Now I won't have the truck distracting me from my work for a few hours ?
gsquirrel02
Andre
<snip> Now I won't have the truck distracting me from my work for a few hours ?
HA! That's what you think!
kab
Carroll County, MD
sotek2345
Engineering Manager
Vacuumed it out to install the Ford all weather mats. Plugging the vacuum into the cab outlets maks that so much easier!
F150ROD
F150ROD
U.S. Navy Retired
Man the crazy part is Iโ€™ve never done this, but will do this from now on lol
Picked up and installed my box link cleats, bed mat, cargo net and rollup cover.
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665787687079
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665787731749
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 1665787749486
skyak
F250, 911, Lightning
Savings of $35.89
That is expensive power. More than double Texas rates. But I guess we do have a ton of solar and wind down here keeping prices low.
Regular150
Shawn
Purchasing
I wonder if the 240 30 amp loses less or no difference?
Initial thoughts on roll up cover? Does the tailgate close properly when the cover is fully closed? I like the no-seam look vs the tri-fold.
I'll have to run a test of that, though I need to install a 14-50 outlet on the new load center.
Could also run a 120v test as well, I think the losses might be greater with reduced voltage/current
Yes, when I first mounted it, I had it too far forward and had 1/8-1/4" gap, so I loosened the four bolts at the head of the rails, slide it back, left loose, close the tailgate and let it push the cover forward enough for just-touch clearance, then retightened the fasteners. It seems good enough, though maybe I may bring it back hair more to get a better seal at the gate.
The roll-up works well, the left & right rail locks engage the cover smoothly as I push the cover into the locked position.
F150ROD
F150ROD
U.S. Navy Retired
Hauling crap tables and chairs around for family members, hopefully itโ€™s considered โ€œreal truckโ€ stuff :ROFLMAO: Enjoy College Football Saturday!
Ford F-150 Lightning ๐Ÿ™‹โ€โ™‚๏ธ What Did You Do To Your Lightning Today? 96837942-4102-4564-8AC4-DC1411350415
