Heated steering wheel stopped working
Sc954rr
Scott
NJ
F-150 Lightning, Volvo XC90
Just seeing if anyone else heated steering wheel seemed to have stopped working after the latest update to 3.5.3 software yesterday. It was working yesterday morning but today not so much, I pre conditioned the cabin everything else was good to go but the steering wheel never heated up, I turned the truck on and off once or twice still nothing. Plus there are no alerts in the ford pass app or truck that something else could be wrong with it.
sotek2345
Engineering Manager
There seems to be some issues with preconditioning and the heated wheel. Try getting in the truck cold and see if it comes on for you.
Blaine
Massachusetts
24 ER Lightning Lariat, 24 F150 Raptor, 25 Explorer ST
Construction Consultant
Heated steering on my Lightning Lariat also did not work this morning after preconditioning. Updated software.
BennyTheBeaver
Didn't you hear, Ford is also deleting the heated steering wheel from already built models.
There is a code shortage.
duncanmaio
Duncan
Norwood, MA
I am still on 3.5.2, but had this problem - only when preconditioning - a couple of weeks ago. Deleted all the Departure Times and set everything up again, and now it works fine.
Fryballin
KY
2022 Lightning Lariat 511A Iced Blue, Max Tow
I wonder if there is a time out on heating the steering wheel because I have noticed after pre conditioning that although the steering wheel is not cold, it doesn’t continue to stay “warm/hot” even with the heated steering wheel button on. Makes me think it’s like a defroster where it heats up initially and then kicks off after a period of time. Basically to get the wheel warm from ice cold. But this might be a glitch in the software versus how FORD intended it to work.
IH905
Isaac
Ontario, Canada
2020 Lincoln Nav, Lightning Platinum-On order
Business Owner
Mine works majority of the time, but doesn't work occasionally ever since I got the truck.
Same here, all settings and operational considerations met, but came out to cold cabin and all.
I turned it on manually, nice & toasty in only a few minutes.
Sc954rr
Scott
NJ
Just went out after letting the truck sit for little bit and the heated steering wheel works fine now, I turned it on/off few times and had no issues with it. Maybe a weird pre-conditioning bug like you mentioned
sotek2345
Engineering Manager
Yup - I noticed that the second day I had the truck. No idea why it does that.
robert5090
Robert
Edmonton AB
F150 Lightning, 2022 Ford Expedition
Sales
My heated steering wheel started to not work 50/50, I work at the dealer and the tech said the module inside the steering column is friend. Now it is completely dead. Waiting on a new module that doesn't exist.
Beans
Phil
Beaver Dam, WI
Acura RDX, Toyota 4 Runner
I wonder if that's what a lot are seeing? I have similar issues to the other posts, sometimes it works, sometimes not. I made one appointment with the dealer and then canceled the next day when it worked, figuring they won't be able to tell me anything other than it's working now.
