SmoothJ
New Jersey
2022 F150 Lightning
I just got the update today/tonight. I went to pickup my little guy and it showed I had a update pending install. So I installed it now vs waiting till my usual time for all installs.
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation C69916E3-42FD-4842-B417-6757875BD1E7
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation 0CB626A4-0BF3-4025-B77C-3E47363865CC
Capertrj
Ricky
Maine
2010 F150
09/19 build.
truck asked for update and confirmed times and dates.
- pushed updated from truck at 80% SOC plugged in. FAILED
- this Time went on FordPass to start charging from 80% to 100% ( maybe to boost LVB). This time it took longer but it still failed.
- I went out now at 82% SOC and restarted the update. killed every light , threw every key fob down the way.
It took longer but I just got a failed to update. It’s funny this time of the year I haven’t drove since like 5 days ago. Maybe this update isn’t meant for me.
(southern Maine 1.9-2.2 highway and 2.5-2.8 or better around town)
Capertrj
Ricky
Maine
2010 F150
09/19 build.
Another swing and a miss. She is juiced up and being fed energy . I don’t get it.
F150ROD
U.S. Navy Retired
Updated successfully. Charge settings still showing 90% on the app, should I trust it?
Farmford42
WA
69 Bronco
Farmer
Firestop
Firestop
Well, I knew it was going to happen sooner or later….the update finally arrive today and has failed multiple times.
Given that you have sent me an OTA that provides me no value @Ford Motor Company , I could care less as to whether it installs or not…..???
dovetaildan
2022 F150 Lightning
Got the update yesterday after the truck sat idle for a week over the new year holiday. First time it tried and failed to install the update. Drove a short trip to the store and back. Came back and tried the update again and it worked.
F150ROD
U.S. Navy Retired
Yeah I should have gone I to the truck and changed all my setting again. Although the App had 90% it still went to 100%
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation 573A6963-0766-4932-883D-202E2331C985
ddbrooke
Natrona Heights, PA
I received the notice that I had a pending update last evening and was showing that it would install at 1am. My truck was already plugged in to my FCSP. Shortly thereafter the truck stopped charging and the light on the charge station went white. I unplugged, flipped the breaker, and started over again. It charged for almost 4 hours, 85%, the faulted again. I guess it's possible this pending update had something to do with these two failures. I've had the FCSP installed for a week and it's worked fine the other 3 times I used it. I have no visibility to the FCSP because I can't get it to connect to my WIFI.
The update completed and shows success at 1:22am.
F150ROD
U.S. Navy Retired
FCSP probably needs to be updated. I had the update installed last night during charging hours. Charging stopped while the truck was updating and then continued once the update was complete.
ddbrooke
Natrona Heights, PA
The only problem is I can't get my charge station to connect to WIFI and I'm not willing to start adding range extenders to my network or an additional router.
The problem probably comes back to my Xfinity system. I don't have a separate router, the Xfinity X1 handle that along with 3 Xfinity pods. That system doesn't allow any customization or visibility to what is connected and how it's connected.
F150ROD
U.S. Navy Retired
Keep trying, I had to attempt at least 8 times on Spectrum before it went through. Also make sure its on 2.4 gHz. I did have to press the reset button those 8 times also as I would make it through a couple of steps and then the connection would time out.
I'm able to see my FCSP connected through my Garage POD on my X1 network.
Is it possible to arrange your pods close enough to reach the garage or is just way outside the range of your network?
