Heated steering wheel not working after last update
ctuan13
Chuck
Pittsburgh, PA
Have you done a forced reboot of the SYNC System? Done a 12V disconnect?
IH905
Isaac
Ontario, Canada
2020 Lincoln Nav, Lightning Platinum-On order
Business Owner
I find it only doesn't work if I have cabin preconditioning temp set to "warm", so you have to choose whether you want the truck warm before you leave the house and then drive with no heated steering wheel, or turn cabin temp "off" and then enjoy the heated wheel during the drive.
theblunden
NC
2023 F150 Lightning XLT
Anyone else?
They removed the coding for it due to a "chip shortage" so no one has a heated steering wheel anymore ???. I feel pretty lucky that my MY23 XLT had zero items removed. Barely dodge the overhead truck bed 360 camera just got screwed on the price hike
twixr3000
Ed
nanaimo bc
Mach E / 22 Platinum ER
hmmm...I will have to try that...thanks
Assuming that you're using the departure timer and preconditioning in the morning, try setting the departure time 15 or more minutes before your actual leave time.
By doing this the truck will go to sleep, then the next time you start the truck the steering wheel warmer should activate and will warm up pretty quickly.
twixr3000
Ed
nanaimo bc
using the 15 minute cabin warm up the heated steering wheel works but not when I "precondition as per IH905 ...kinda dumb way to have it if you ask me lol
Interesting divergent experiences, I actually did this yesterday, it worked for me, I can't explain why but possibly try a bit more down time ~20 minutes.
Understand that the when you enter the vehicle the wheel won't hot super hot, like you would find with remote starting. But it will turn on and begin warming up quickly there after.
I've been doing this work around for awhile to resolve absolute cold wheel with NO heating that happens when you ~START~ the truck while it is on or within 15 minutes of the actual drive time that equals your programmed departure time.
@Ford Motor Company this bug needs fixing!
EdRudy
Ed
Springfield, VA
Mine never works when preconditioning... Even if I wait 15, 20, or 30 minutes. What I do now is charge to 90%. About 20 minutes before I leave I click on the Charge to 100%, about 10 minutes during the Charge to 100% I remote start the truck to pre heat the cabin. Even in extremely cold weather it keeps the Power Gauge at 100% and the steering gets and stays warm. It also adds about 2% more battery charge... :)
Yup, this technique works too.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
Great feedback sir. I'll have to try this tomorrow morning. Hopefully this will end the long winter of discontent for my wittle digits ;)
luebri
Neenah, WI
^^^^ This is key! ^^^^
For the workaround 15 - 25 minute workaround (I've been doing 25)! It may not be warm every time when you get in which is still annoying. That said you will have manual control every drive. The most annoying part of the Precondition steering wheel bug was the lack of ability to turn it on for the whole drive.
Kev12345
2023 Pro ER
2023 XLT’s exist? You must be one of the lucky 5!
theblunden
NC
