New guy problems
Mrvette
Rick
Wapwallopen,Pa
2023 Ford Lightning XLT
Hi all,
Just picked up my new XLT Lightning last night. I put the charger together and plugged it in to the regular wall socket. The light on the charger turned yellow and I plugged it in to the truck, and nothing. Tried it a few more times, jiggled it and nothing. Is there a button on the dash or somewhere that I missed pushing. I have to put up with the regular wall plug until I gather all the materials to put a dedicated charger in the garage. I called the dealer and they said to call service in the am.
Thanks,
Rick
cyclops
T
Iowa
2023 F150 Lightning, 2022 Mach-E, 2023 Raptor R
If it is just the amber light that is on, try removing and replacing the 120V dongle from the top of the charger. Error light meanings posted below:
Service
Ford F-150 Lightning New guy problems 1
TheWoo
Manhattan, KS
First thing I'd do is take the dongle out and reseat it. It's a bit tough to get it fully seated sometimes and that will cause a fault.
Danface
Dan
Central Mass
2023 Lightning XLT
Is it Standard Range (SR) or Extended Range (ER)? Did you get a Level 2 charger with the truck?
Mrvette
Rick
Wapwallopen,Pa
Hi all,
Sorry for the basic questions. I'm sure I will have a few more. The truck is the standard range and is beautiful. I will try reconnecting the plug. Is there a short list of the material I need to run a line to the garage, it's about 60 feet.
Thanks,
Rick
Dom630
If by chance you live in an older home (built pre-1970) its possible that your outlet may not be grounded. The ford "charger" will not function without a ground. I ran into this problem before installing a dedicated 240v outlet in my 1950's built home.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Not really, there are so many variables concerning your existing system. Best bet is have an electrician come and give you an estimate.
If you plug in the charger and it doesn't show a blue light, then stop and reset the dongle or try another outlet. Until you get a blue light showing, no sense in plugging it into the truck.
Woohoo!! The truck is now charging. It may take a day or two but it's working. I think the outlet was the problem. Thanks so much from a newbie.
Rick
Or 3.
It will charge at the rate of 1.1kW per hour. Take the percent battery you're at, and do the math, and you'll know how long it will take (you should be charging to 90%, see below).
(98 x (.9 - X)) /1.1
Assuming you're at 20% SOC, (98x (.9-.2)) / 1.1 = 62.4 hours.
To set the charging level, after it's been charging go in the truck, into charging, and you can pick the location and set the limit. Or, more quickly, you can pick a one-time limit of 90%.
while some of us are 'electrically confident', and handle our own electrical needs, there's no way we can help you with yours - there are just WAY too many variables.
it's like folks who compare their own Auto insurance to another family's Auto insurance - there are SO many variables that even what might 'look' the same, is NEVER exactly the same.
Mrvette
Rick
Wapwallopen,Pa
I was at 35% but it's still a long time.
Rick
Mrvette
Rick
Wapwallopen,Pa
What % charge is the lowest that battery could be run down safely? I don't know if that was phrased right, but is there a cut off point?
Rick
EdRudy
Ed
Springfield, VA
There is no "real" cutoff point but from what I've read about charging levels I've learned that most, (not all), use the 80/20 rule, meaning don't charge above 80% and don't discharge below 20%. Some charge up to 90 and 95%. Only charge to 100% when traveling long distances. It's also best to store the truck at around 50% charge if storing for long periods of time.
