ctuan13
- First Name
- Chuck
- Jul 31, 2022
- Pittsburgh, PA
- 1979 Continental, 2022 F150 Lightning, 03 Marauder, 2024 F350
So long story short I'm having an issue I've never had before in my two years of ownership. I pulled out of my heated garage and left my house and like always had my temp set to around 73, vents set to face and floor and the AC switch set to on. I just had a few local errands to run, but after driving about 10 minutes I noticed it felt more humid inside the cabin and I smelled the characteristic smell you get when the compressor cycles off and the condensation on the evaporator begins to evaporate. Within minutes, every window was fogged up so badly I had to pull over because I was driving blind.
I tried every conceivable setting, but the compressor didn't seem to kick on and the fog wouldn't dissipate. Finally I opened the windows to try and eliminate some of the humidity. That combined with max defrost did seem to make some impact, but the entire rest of the drive, there was at least some condensation on the windshield. For reference the Heated garage is ~60°F and outside temp was ~27°F.
When I got home I pulled out my XTool bidirectional scanner and immediately did a full system scan. Other than the expected minor codes for the TCU being disconnected, there were none. I even scanned the ACCM (Air Conditioning Control Module) specifically and all seemed normal, with no faults. When I set the system to Max AC the life data showed the compressor kick on, pull an appropriate amount of amps and soon after the vent Temps began to drop. And yet if I set the system to 73 with the AC switch on, even running for an hour, the compressor didn't kick on once even to periodically dehumidify the cabin. Same with max defrost.
I've never had this happen before and I'm not sure if this is just some sort of Lightning climate control peculiarity or a serious issue. But without any codes and it being difficult to reproduce without the right conditions, I have my doubts that a dealership visit will accomplish much. Any thoughts, experiences or advice?
