Mike G
N. AL, USA
I did still have the glare-free icon on the IPC after the IPMA update. But the full glare-free 'effect' of the lights shutting off certain segments so as not to affect oncoming traffic stopped. When I checked the IPMA with FORSCAN I found that I had to change this value back to "9".
706-01-01 xxxx xxx9 xx--
I fixed that yesterday and ran the Read Configuration tool to upload the settings to the cloud so that they will hopefully now be persistent across future updates.
Now if I could only figure out why the clock in Sync keeps reverting to 12hr time everytime I start the truck, instead of the 24hr time format I prefer that would be great.
I've seen this come up on this forum before....I don't remember who was the member that had this issue. This fixed it:
Ford F-150 Lightning ECU module programming guide using FDRS 1733946948581-qy
Mike G
N. AL, USA
Javier, I will go out and do that today. And thanks for pointing out where that was in the spreadsheet, I couldn't find it yesterday.
I'm just hoping that when I do the change it will actually 'stick'.
BTW while we're on the FORSCAN topic. For those of us who have the BC lane change feature working...how do you get the graphic lane change 'squiggle' animation to show up in the IPC? Mine just has a text that comes up and either says that it's "Preparing to..." or "Changing Lanes" etc. but the graphic of the truck in the center stays the same without showing the animation.
Same on my truck. That animation is missing from the IPC software on the trucks. Only the Mach E has the cool lane change thingy. Hopefully we get it with a future IPC update.
Maineiac12
Iowa
My 2024 with BC 1.2 from the factory has the animation so I’m sure you’ll eventually get it…. In 2030.
The 24 are different. Their IPC is managed by the APIM now. Same with the 24 ICE Mustang......not sure if the 24 Mach E switched to this architecture, too. The 24 Mustang got new gauges in the IPC from an APIM update.
Maineiac12
Iowa
That’s cool! I had no idea it worked like that on the 24’s.
L1GHTNING
Can anyone explain what this is and if I need it? My truck was made in 9/24…do you think it needs updating?
Does your truck have modules that have an available update - Probably (my 2010 F-150 did). Will these updates give you any useful functionality. Probably not. And those that are useful (like a slightly newer BC than what you got or karaoke) will come via OTA updates "soon".
The useful mods you're likely not gonna get OTA are with FORScan. Like glare-free headlights, disabled beeps and chimes, etc. And then there are hardware mods like getting back the deleted lighted cup holders.
And getting a Tesla Supercharger adapter is the best of all updates.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
Ford F-150 Lightning ECU module programming guide using FDRS 1734496633883-cg
Is it normal that ACM/RFA/PSCM are still on the SW update page even after installation?
installed 2 times and it still shows up
also is there any hack to get BCM installed? need WAL...
PJnc284
Garner, NC
ACM and RFA not clearing is expected but haven't seen anything on the PSCM not clearing. For the BCM, you'll need to sweet talk your dealer.
Mike G
N. AL, USA
I'd do (or redo) that PSCM update. It will also drag the IPMA into the mix since they are scripted to be updated together. But if the IPMA has already been successfully updated, FDRS will recognize that and skip over the reprogramming and configuration, and go right into the PSCM next. That PSCM by itself takes no more than 5 minutes normally.
astrand1
Alex
Studio truck driver
That was me! (I think) I had the same issue where it would always go back to 12 hrs. This fixed it.
astrand1
Alex
Studio truck driver
I’ve got 1.4 on my 23 and I don’t get any text on lane changes at all. It does auto lane change with the turn signal but other than that there is no indication.
Mike G
N. AL, USA
So you don't see a little animated line showing the lane change as it happens either?
I get a little text "subtitle" that says it's preparing to change lanes, or changing, or whatever, but no animations.
