klossfam
- First Name
- Jeff
- Mar 1, 2022
- East Amherst, NY
- 2022 Lightning Lariat & 2022 Hyundai Ioniq 5 Ltd
- Occupation
- Retired
Agreed and that's why I posted. My truck is parked outside and granted I had 30+ miles of use with 10 miles of preconditioning for this session. It was 27 F so still cold. Lowest I saw until 80% was 129 kw which is very solid. If you removed the 80-83% at 54 kw, I'd estimate the true average rate on this charge as 140 Kw.I think there’s been plenty of previous DPs where people have hit max charges like this, but the second part would be a MUCH bigger deal if true. The lower part of the curve has typically been around ~120 kw until now. Getting ~140-150kw after the initial surge would be huge, since that is the longer part of most charges.
That is very good and having owned an 800V car since Feb 2022, I can say charging curve is what is important. Another thing never talked about (esp with Hyundai EGMP) is in summer they get so hot charging, that your first 10 miles back out on the highway are NOT efficient as coolant pump and fans are cranking and you will see only 2.0-2.4 mi/KW until things cool down. So your 240 KW rate is cool 'on paper' but due to the initial efficiency loss, your range can be hampered.
