Andrewbens
Mine is a 2023 and I received the 10.3 update recently purchased in march of 24Curious what year is your Lightning, and when did you buy it?
Have you received any OTA's !!!?
OK, that's a great sign, that updates are going to your truck, so if I understand your question, it's more about the native Ford navigation app having the Tesla sites, long time promised, who knows when that will happen, for now we're all using either Google, Apple or third party apps for locating Tesla stations, it's certainly a hodge-podge patch work at the moment.Mine is a 2023 and I received the 10.3 update recently purchased in march of 24
Which makes preconditioning for tesla chargers impossible* at this point, correct?OK, that's a great sign, that updates are going to your truck, so if I understand your question, it's more about the native Ford navigation app having the Tesla sites, long time promised, who knows when that will happen, for now we're all using either Google, Apple or third party apps for locating Tesla stations, it's certainly a hodge-podge patch work at the moment.
Current has no impact on cost. A kilowatt-hour is the same whether it is delivered at 5 amps or 500 amps.500 amps, ok. The level of damage to the battery and the fact that this won’t even be offered (like at a fast charger) are the major issues. I mean it’s cool and would really reduce charging times but the 500 amp service would make charging very expensive in this current economic climate.
If you have an Android phone, google maps in android auto allows preconditioning.Which makes preconditioning for tesla chargers impossible* at this point, correct?
*challenging; requiring routing to another dcfc via the native navigation while using your phone to navigate to the tesla charger. That's the only way I'm aware of, at this point.
I’m sure Tesla is much further along. The need for that amount of current is indicative of solid state and newer technology that will likely need those levels.I believe tesla has offered this speed of charging for some time now. There were a few reports of 190kw many months ago which would be 500kw consumed.
It often takes thousands of products and many many miles of testing to determine if something is detrimental. Ford now has three years of owners information to start to evaluate dcfc and its effects on battery degredation. Tesla DNA others have literally been doing this for over a decade now.
The 10 minute and drop-off thing is a Ford deal, not EA.
Only if it works...I have an update past where that was supposed to work but it's not working. I'm wondering if the truck is missing a different update in a different module or something that makes that work.If you have an Android phone, google maps in android auto allows preconditioning
Not trying to be argumentative, but you are confounding so many issues that have nothing to do with each other. You may really want to read up on a lot off what you are talking about.Oh absolutely. Maybe I needed to clarify what I was saying. Talking about how the costs associated with 500 service, upgraded fast charging, etc. it will make it worse than electrify America which is 50-60 cents a kWh on the low end. Additionally, if the truck was made for that input why not just start there?
Technology can be adapted but rarely if ever can it be upgraded without providing the hardware to support the software changes. Before you say so, I’m not bitter or negative about anything with electric vehicles, but this is white noise. Ford needs to do better in aspects that matter, like whatever the abbreviation for the home power is (not the charger but the inverter), or working on expansion packs for the batteries or fast charging capacitors that can be swapped out or carried on long trips, or just maybe a range extender. Like get one out soon, because it’s great to have fast charging but not if you are designing your life around public charging that can be, many times, less than reliable.
Lastly, I’m really on an electrify America bashing session. Not because I think the chargers are terrible, because they usually are the fastest but because of the cost. The other part is that electrify America was supposed to have it setup for 500a anyway, which would go for 10 min then drop off. I don’t know of any vehicles charging with that level of current, so I guess we can see.
I’m really not because I consider them linked. It’s easy to say you can now charge at a certain current level. That’s something that can be switched by changing computer code to allow it to happen, is there a hardware requirement? Yes, but how many times do you upgrade the software on your iphone(don’t get me started on android) and over a much shorter time your phone doesn’t operate at the level it started with because the throughput is way more than the hardware can handle?Not trying to be argumentative, but you are confounding so many issues that have nothing to do with each other. You may really want to read up on a lot off what you are talking about.
The Lightning already charges at 450a I believe. Even at 500a it's not going to hit 200kw charge rate. That's still under what most (all?) Superchargers can do, and every EA station I've been to has a couple 350kw chargers.500 amps, ok. The level of damage to the battery and the fact that this won’t even be offered (like at a fast charger) are the major issues. I mean it’s cool and would really reduce charging times but the 500 amp service would make charging very expensive in this current economic climate.
You left out pertinent information, I fixed it for you.The Lightning already charges at 450a I believe. Even at 500a it's not going to hit 200kw charge rate. That's still under what most (all?) Superchargers can do, and every EA station I've been to has a couple 350kw chargers [that don't work].
