Vulnox
- Mar 19, 2021
- Livonia, MI
- 2024 F-150 Lightning Platinum, 2025 Mustang Mach-e Premium AWD
I got the truck this past Thursday, but did a few things to it.
-Installed Bakflip MX4, now on its fifth F-150, but first EV F-150. This tonneau cover has been a trooper.
-Installed dash cam
-I got the Ford molded mud flaps and used the paint marker idea from this thread but we ended up doing white instead of the blue. I liked the blue idea, but the white is a lot easier to see and goes well with the truck.
-I did the adjustment for my driver door as I could hear the seals rubbing over bad roads that others on here discussed and provided a solution for. Very easy and truck is much quieter.
-My usual array of FORSCAN mods to turn off the double honk (although I learned after this is a menu item on 2024s), removed the "full view not available" from the rear camera, and changed the number of signal flashes for lane changes.
I have the frunk nets coming today, which is less a mod and more just adding in something Ford stripped out, but happy so far.
I am debating if I want to reinstall my bed boxes or do something different. Having the frunk opens up a lot more options.
-Installed dash cam
