New BlueCruise Version 1.4 - Rollout IPMA-24.204.10.9
I drove it the moment It was finished whirring with the update, mid day. It’s not the same truck, everything is sluggish.
what can be done now to get it back to normal?
Hopefully it should be back to ~normal~ today when you drive it.
The Weatherman
Dean
South Central KY
@TaxmanHog
Happy to see you finally received BC 1.4. Not sure how we got separated so far apart on updates. There for most of the year I would receive an update about a week after you did. For this one I finally received BC 1.4 back on June 6th, if memory serves me.
🤷‍♂️ there certainly seems to be no rhyme or reason to FORDs OTA’s🤷‍♂️.
Anyway, happy motoring.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Just as an FYI I already has the front sensor CSP done (which I understand to include the software for 1.4). The OTA 1.4 update said it would take 6 minutes and it ended up only taking 4. All it had to do is write whatever final configuration to activate it.
I did get a chance to briefly test it out. I like the auto lane change and that it scoots you over when next to a big truck. There was also a section where one lane divided into two where the lines widened all the way before center lines showed up. The truck handled it and kept going into the lane straight ahead. It slightly moved over at the beginning of the split and moved back, as if it was centering in the lane until it realized that the outer line was quickly moving away. I was expected it to shut off.
vic7780
Victor
Quantico VA
F-150 Lighting - Atlas Blue, Max Tow, 511a Package
Citizen
luebri
Neenah, WI
I got my 1.4 update today and just had a very brief ~5 mile stretch to test.
I am probably one of the first to get this update twice! 🤣
On Saturday I got this again, now on my 2nd lightning that I bought used in July. To be honest I had no idea what version of Bluecruise the truck was even on since there was no trial subscription on the used Lightning and I am not planning to pay the subscription fee except on the very rare case in which I would be doing some extended travel. As a 2nd owner though, It was good to see OTA updates coming through on the used truck. The last one I was aware of was installed 2 days before I acquired. I'm not sure if that was coincidence (my guess) or something the dealer somehow was involved with.
One thing to note... not that I am surprised but Ford is totally missing a upsell revenue opportunity if they are not chasing a Bluecruise update with brief trial offer (e.g. 30-day) for Drivers currently off-subscription so they can try and get them hooked into it after testing improved version. I doubt it would work on me, but it probably would work on some... or more likely a certain percentage would just forget they signed up for subscription which seems to be half the economy right now, which is people signing up for something and forgetting to cancel!
DamSea
Waldorf, MD
F-150 Lightning Lariat ER
Truck is currently at the dealer. Apparently I needed to have a GCM module fix/updated as an problem within it would constantly report a low battery erroneously so all updates would fail. They are currently updating everything available for my truck so I shoud be to go for awhile.
LiteNing
Nic
'23 F-150 Lightning Lariat
1's and 0's and lambdas
You might be the first one to get it twice, but I think I'm one of the first one to get it twice in the same truck! First time was September 6 and now again today.
I take photos of the release notes each time I get an update. Everything is exactly the same, including version number (24.204.10.9), except for one paragraph in the middle:
"Lariat, King Ranch, Platinum and Limited Series customers will receive and upgrade to their ACC system that includes the following:" and then follows the usual paragraphs about Predictive Speed Assist.
All the 1.4 features seemed to work the first time, so I wonder why they're sending it again?
BriyGuyUSA
Glyn
Atlanta, GA
2023 Lariat ER 511A Antimatter Blue
IT Stuff
I got the update last night.. Funny thing is, I already had the update. When I purchased my truck 3 months ago it had all the software updates applied, Walk Away Lock, BlueCruise 1.4, Frunk updates... Seems Ford does not keep track of which trucks have the software already. Now I'm concerned that when I turn it on today something will have been overwritten and got screwed up.
Ford F-150 Lightning New BlueCruise Version 1.4 - Rollout  IPMA-24.204.10.9 IMG_3195
PJnc284
Garner, NC
It's possible that previous owner also updated it manually also and didn't have all the config changes updated. I updated everything in mine with FDRS back in April but I also disabled the annoying curve control in Forscan. Couple weeks later I got the official OTA and the only change was that it flipped that bit back. Fast forward to a month ago and I got the toggle updates OTA. I had already enabled the 1.4 and WAL enable/disable but didn't add the wal feedback since I didn't want the sound. Of course the only thing the OTA changed was that I now have the feedback toggle.
