angel gago
angel
ford lightning 2023
custodian
*Slow clap while slowly standing up…
Well done sir, well done. I’ll be following this thread.
Rolled the dice on this ER battery on eBay. Anyone else out there do this yet? Wish me luck boys and girls.
Keep all of us posted for those of us with the standard range battery that would be the best thing for us all to go extended range
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
Wow- can’t wait to hear how this goes. I was under the impression that Ford had “firmware locked” out SR owners from doing this. But hopefully you can figure it out- keep us updated!!!!
BhamDCam
Birmingham
2023 F-150 Lightning Pro ER
Impressed you’re even willing to try this. Definitely following this thread out of curiosity.
Once the SR battery is out, and programming aside, it should be relatively plug and play…right? I could be totally wrong.
The Munro Live tear down videos will likely be your friend.
MidAtlanticLightningClub
F-150 Lightning Lariat ER
Cool project!
I'm guessing the hardware hookups will be straight-forward. However, I suspect you'll need significant changes to your software and firmware, probably using both FDRS and FORScan.
IIRC, the ER trucks have a beefier wiring harness to pull juice faster. You should get the longer range but will have a slower 0-60 and be limited to 10.5 kW AC charging.
kdkool
Atlanta, GA
2023 XLT Lightning / 2023 6.7L Lariat F-350
Cool project!
Yeah I have no idea what to expect on the programming side of things.
Extended range is all I'm after. I have no need for more speed. It's stupid fast enough. I don't have the 80a Ford charger so anything above my current 48a charger a moot point for me.
ClevelandBeemer
I wonder if there is any programming needed…..
