Bad weather mileage - 1.5mi/kWh
pirate4x4lance
Lance
2025 Lightning
Drove home from Las Vegas Airport back to Hurricane, UT on Saturday night. This is a trip I do fairly often (I charge to 80% at a nearby Tesla SC before my flight so I can drive straight home since I can't make a round trip on one charge). Typically I average 1.8mi/kWh @ 75mph on this trip and have gotten as good as 1.9. It was raining like crazy, about 55* and windy. Left the airport at 78% and barely made it home at 5% with an average of 1.5mi/kWh. Glad that's not typical range!
Ford F-150 Lightning Bad weather mileage - 1.5mi/kWh IMG_0731
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Did you maintain your usual 75 mph?
Noticed you grew more conservative with the cruise pre-set lowered to 64
Try a 20mph headwind and you'll really see a big drop.
pirate4x4lance
pirate4x4lance
Lance
2025 Lightning
Yeah the last section of highway before home is 55mph speed limit. The interstate is 75 and 80mph speed limit.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
Mine was getting 3.1 on my commute to work every day at the end of summer. Now it gets 2.0 on the exact same trip if I'm lucky. A 35% hit due to a 40F drop in temp is wild. Winter is going to SUCK. Might have to drive my Jeep instead.
B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
Set a departure time for your morning commute and it won't be as mch of a hit, if any.
pirate4x4lance
pirate4x4lance
Lance
2025 Lightning
Yeah that sucks! Thankfully it doesn't get that cold here in the desert. My battery temp was about 70* on this trip.
blb228
Brett
2024 Flash Agate Black
I would happily give up some of what I feel is aggressive battery-degradation management if it meant getting more real-world range.....
camflan
25 Lariat
Just happened to us on Wednesday, our first ev road trip. Between Ames, IA and Albert Lea, MN we saw just over 1 mi/kwh for over an hour (kept bouncing between 1.0 and 1.1). Wind, cold, and I’m guessing a very slight grade (not noticeable but shows in ABRP). We had to make an emergency 10 minute stop at a 65kwh charger to make Albert Lea at 8% instead of the expected 28% when we left Ames. Kept decreasing speed too, 75 -> 70 after about 15 minutes then had to drop to 65 for 15 or so until our emergency pit stop
