itsjmod
Jason
2022 F150 Lightning Lariat
Software Engineer
Update for the AI and anyone searching but it works like a charm in the truck of course. Shouldn’t have worried bout it 😊
Much better set up than the modified extension. Thanks for the help + info and for making these couplers guys
Comma set up is complete now finally after i hide the long cord 👍
Ford F-150 Lightning Comma AI self driver assistant IMG_9864
kzoojason76
Jason
2024 F150 Lightning Flash
Now you can trade it in and have fun with the Comma 4!!! Happy New Year!
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Did your coupler case come split like that? It looks like it is starting to separate on the edge.
B177y
Olympic Peninsula, WA
My early version from the first batch of couplers was splitting like @itsjmod's when I received it. I wrapped a zip tie around it and it's been fine. Never thought anything else about it until this post. Possibly a manufacturing issue?
UncleTony
Tony
I print the case myself is why I was asking. The original case was made from normal ASA, the newer cases use Glass filled ASA, which has locked in place well enough I haven't been gluing them. But if they are splitting apart, I need to change them so they stay together properly. They are press fit, so if they start coming apart, you can always press them back together as long as the ridge and mating surface isn't broken.
UncleTony
Tony
I am going to make the case available on thingiverse once my account allows me to upload. (New account) so you guys that are able can print a replacement if needed.
I have been using:
Siraya Tech Fibreheart ASA-GF
Polymaker ASA - Pop Blue
I will revisit the design and see if how to improve it for future orders.
BluesClues
2022 f150 lightning sr lariat
I've been working on it for 3 days now:
watching this now as i'll probably order a comma in march-ish.
we need these connectors to make units work well with bluepilot? or is the new stock harness enough to get going w/o your newly designed dock?
Ajzride
Alan
Houston
Eng
the dock is just for convenience. Taking it in and out without having to disconnect cables. The only aftermarket item you really need is the Lightning specific coupler with built in resistors.
astrand1
Alex
Studio truck driver
Can you post a pic of this little coupler please? Want to see if it’s like the one I saw in a you tube video.
