As the saying goes, if it works don't fix it.
I thought you were looking at options because you weren't satisfied, but if it works for you that's all that matters.
Unless of course we all decide to pool our data into a giant, common, database - now that would be pretty cool !
The thought is on my mind. Part of my redesign is to enable multiple vehicles and different (changing) configurations per vehicle (tire size, towing, etc) Not sure if it could scale appropriately, or how to host it, but the concept would be cool.
I may have missed it, but is there a list of PID's we have/need?
galstaf
North Georgia
2015 LEAF x 2, 2022 F150 Lightning Lariat ER (511A trim)
community offgrid training
) but it is also different when the truck is left on (which I assumed the guy doesn't since he's charging at work).
Actually the truck was left on. We have a secured facility; nobody messes with anything. I had the heated seats and steering wheel on so I could come do a warm up every now and again as it was pretty brutal outside. Plus I had the Pro Power on to charge a couple of power tool batteries.
So; if the truck is left turned on, it delays charging until the battery hits 68F?
Forgive my ignorance, I am still less than a month into my first ever Ford anything.
What are you using to capture this logging information and can it log charging data with the truck switched off?
When it is super cold, will the AC charging commence faster with the vehicle switched off?
It still takes a charge but at a slower pace, which more noticeable when DCFC charging.
Read about my experiences charging in frigid conditions 2/7 to 2/8 at Ionna
galstaf
North Georgia
I read through it. Apparently the pace with the 32A Ford charger was so slow it showed up as no progress at all. After an hour to 2 hours it would start to progress.
I have done some more logging and here is the consolidated list. These still need to be validated.
Copy into a text editor or excel to turn into a csv. (note, excel takes the header value and converts a bunch to scientific notation. To fix it use the text import and set that and the PID value to Text, not general)
Name,ShortName,ModeAndPID,Equation,Min Value,Max Value,Units,Header,Description
AC Status,AC_STAT,229938,A,0,1,state,733,HVAC: Compressor Status
Blower Speed,BLW_SPD,22995A,A,0,100,%,733,HVAC: Blower Speed (100 is OFF)
Heated Seat Drvr,H_SEAT_L,229801,A,0,3,state,733,HVAC: 0=Off 1=Low 2=Med 3=High
Left Blend Door,L_BLEND,229B02,A,0,100,%,733,HVAC: Left Actuator Pos
Right Blend Door,R_BLEND,229B03,A,0,100,%,733,HVAC: Right Actuator Pos
Evap Temp,EVAP_T,224057,A-15,0,100,°F,733,HVAC: Evaporator Temp
Recirc Door Pos,RECIRC,229B00,A/2.55,0,100,%,733,HVAC: Recirculation Door Position
Cabin Heater Status,HTR_CAB,224836,A,0,255,raw,733,HVAC: Heater Core Status
L DRL Status,L_DRL,2240E7,A,1,2,state,7C4,LDCMA: 1=OFF 2=ON
L High Beam,L_HIBEAM,2242BE,A,1,2,state,7C4,LDCMA: High Beam Status
L Turn Signal,L_TURN,224255,A,1,2,state,7C4,LDCMA: Turn Signal Status
L Low Beam,L_LOBEAM,2242A0,A,1,2,state,7C4,LDCMA: Low Beam Status
L Static Bending,L_SBL,224266,A,1,2,state,7C4,LDCMA: Static Bending Status
High Beam Status,HIBEAM,2242A0,A,1,2,state,7C4,LDCMA: High Beam Output
Tire Press LF,TP_LF,222813,(A*256+B)/20,0,60,psi,726,BCM: Left Front Pressure
Tire Press RF,TP_RF,222814,(A*256+B)/20,0,60,psi,726,BCM: Right Front Pressure
Tire Press LR,TP_LR,222816,(A*256+B)/20,0,60,psi,726,BCM: Left Rear Pressure
Tire Press RR,TP_RR,222815,(A*256+B)/20,0,60,psi,726,BCM: Right Rear Pressure
Tire Temp L,TPM_L_T,22280B,(G*1.8)-40,-40,200,°F,726,BCM: Tire Temperature
Stop Lamp CHMSL,CHMSL,2240F5,A,1,2,state,726,BCM: Center Brake Lamp
Brake Pedal Travel,BRK_TRAV,222823,(A*256+B)/2540,0,5,in,760,ABS: Brake Pedal Position
Brake Pressure LF,BRK_PRES,222B28,(A*256+B)*0.145,0,2000,psi,760,ABS: LF Brake Pressure
Lateral G Force,LAT_G,222B0C,(SIGNED(A*256+B))*0.004,-2,2,G,760,ABS: Lateral Acceleration
Parking Brake Sw,PK_BRK,222B00,A,0,255,state,760,ABS: Parking Brake Status
Steering Angle,STR_ANG,223302,((A*256+B)-7800)/10,-900,900,°,760,ABS: Steering Wheel Angle
Steering Current,STR_CUR,22330C,A*0.2,0,100,A,730,PSCM: Steering Motor Current
Steering Torque 1,STR_TQ1,22EE05,(SIGNED(A*256+B))*0.737,-500,500,ft-lb,7E4,PSCM: Steering Torque 1
Steering Torque 2,STR_TQ2,22EE07,(SIGNED(A*256+B))*0.737,-500,500,ft-lb,7E4,PSCM: Steering Torque 2
Accelerator Pedal,APP,22F449,A*100/255,0,100,%,7E0,PCM: Accelerator Position
Baro Pressure,BARO,22F433,A*0.145,0,20,psi,7E0,PCM: Barometric Pressure
Coolant Temp,ECT,22F405,(A-40)*1.8+32,-40,250,°F,7E0,PCM: Engine Coolant Temp
Vehicle Speed,VSS_MPH,22F40D,A*0.621,0,120,mph,7D0,Vehicle Speed (mph)
Battery Temp High,BATT_T_H,224800,(A-50)*1.8+32,0,150,°F,7E4,BECM: Max Battery Temp
Battery Temp Avg,BATT_T_AVG,22FD70,(B-51)*1.8+32,0,150,°F,7E4,BECM: Avg Battery Temp
Battery Current L,BATT_CUR,22480A,(A*256+B)/336,-100,100,A,7E4,BECM: Low Range Current
Battery Energy Est,BATT_kWh,224848,(A*256+B)*0.002,0,150,kWh,7E4,BECM: Energy Estimate
SOC Actual,SOC_ACT,22F45B,A*100/255,0,100,%,7E4,BECM: Raw SOC
SOC Displayed,SOC_D,224845,A*0.5,0,100,%,7E4,BECM: Dashboard SOC
Charging Power,CHG_PWR,22484E,(A*256+B)*5,0,150000,W,7E4,BECM: Charging Wattage
Charge Status,CHG_STAT,22484D,A,0,5,state,7E4,BECM: Charge Status Flags
Coolant Inlet Temp,COOL_IN,224846,(A-50)*1.8+32,0,150,°F,7E4,BECM: Cooling Loop Inlet
Coolant Temp 2,ECT2,22483A,(A-40)*1.8+32,0,150,°F,7E4,BECM: Secondary Coolant Temp
Conv High Current,CONV_HI,220582,(A*256+B)*0.05,0,500,A,7E4,BECM: DC/DC High Current
Conv Low Current,CONV_LO,22D118,(A*256+B)*0.01,0,100,A,7E4,BECM: DC/DC Low Current
L Headlamp Swivel,L_SWIV,227102,(A*256+B)/6.4,0,360,deg,734,HCM: Left Swivel Angle
R Headlamp Swivel,R_SWIV,227104,(A*256+B)/6.4,0,360,deg,734,HCM: Right Swivel Angle
ECU Delta Temp,ECU_DT,22DD81,A-18,0,100,°F,7E4,BECM: ECU Temp Delta
Cell Voltage Var,CELL_VAR,22483F,(A*256+B)/400,0,1,V,7E4,BECM: Cell Variation
Current Range HG,CUR_HG,22FD39,A,0,255,range,7E4,BECM: Current Range High
Current Range LW,CUR_LW,22FD38,A,0,255,range,7E4,BECM: Current Range Low
BECM Info 02,BECM_I02,22F800,A,0,255,flags,7E4,BECM: Info Flags
Power Remaining,BATT_REM,224801,(A*256+B)/500,0,100,%,7E4,BECM: Remaining Capacity %
Motor Torque Pri,MTR_TQ1,22481C,((SIGNED(A*256+B))*0.1),-1000,1000,Nm,7E6,Inverter: Primary Motor Torque
Motor Torque Sec,MTR_TQ2,224822,((SIGNED(A*256+B))*0.1),-1000,1000,Nm,7E7,Inverter: Secondary Motor Torque
Motor Speed Pri,MTR_SPD1,221E2C,(SIGNED(A*256+B)),-6000,12000,RPM,7E6,Inverter: Primary Motor Speed
Motor Speed Sec,MTR_SPD2,224821,(SIGNED(A*256+B)),-6000,12000,RPM,7E7,Inverter: Secondary Motor Speed
Motor Inv Temp Pri,INV_T1,22481D,((SIGNED(A*256+B))*1.8+32),-40,300,°F,7E6,Inverter: Primary Temp
Motor Inv Temp Sec,INV_T2,22481E,((SIGNED(A*256+B))*1.8+32),-40,300,°F,7E7,Inverter: Secondary Temp
Charger AC Volt,CHG_AC_V,22485E,(A*256+B)*0.01,0,300,V,7E2,Charger: AC Input Voltage
Charger AC Curr,CHG_AC_I,22485F,A,0,100,A,7E2,Charger: AC Input Current
Charger AC Freq,CHG_AC_F,224860,A*0.5,30,90,Hz,7E2,Charger: AC Frequency
Charger DC Coup T,CHG_DC_T,22D00C,(A-40)*1.8+32,-40,400,°F,7E2,Charger: DC Coupler Temp
I'm a little confused about these. Is this a min/max current available for the LVB? Also, I don't see current voltage for LVB or the HVB, but I have those (I think from the PID list linked your other thread). I can double check that when I break for lunch.
mr.Magoo
2022 Lariat ER, AMB
I have no idea where @Firn got that from but those are not correct.
220582 is a coolant pump (A) duty cycle
22D118 is the motor current from the steering rack, frunk or tailgate servos (depending on which module your're requesting it from).
The current to/from the DC/DC converter is 224836 (12V / LV side) and 22483A (HV side), both should be 8-bit and 0.01 resolution, directly from the DCDC (746) module.
These are raw from using forscan to log and wireshark to monitor the message traffic. Gemini is then trying to reconstruct from the bits into the PID used and the equation.
These are of course raw from it and hence the need for validation
galstaf
North Georgia
Don't trust the AI not to scramble your data! It will randomly change things and just make stuff up. I
I give it to CGPT then Gemini then back again and so on and have them check each other's work.
Eventually if you can get them to agree it is usually mostly correct. Sometimes. lol
theUNSTABLE
Ryan
github.com
Cyber Engineer
I need to do some reading.....this will be incredibly helpful.
I just put a major change on my project out there, and I (still) have the goal of supporting alternative data sources.
I purchased a WiCan as a plan to support that as a data source, granted I purchased that to originally ingest the data into HomeAssistant and then my project gets data from HASS - but I'll need to read into this and look into it.
