Adventureboy
Adventureboy
Same here big difference from Ancel 200 compared to car scanner. Removed and returned to Amazon.
The Ancel monitor and all other 2-wire monitors, including my BM6, which is probably identical to Ancel anyway, will never be accurate for SOC. It will only be a calculated guess based on the average voltage over time and the ambient temperature. It doesn't have the amperage in/out needed for accurate SOC like the onboard BMS. Voltage, on the other hand, is quite accurate with the BM6.
My experience is that my BM6 always calculates SOC under the OBD2 BMS value on our Lightnings. This is probably because the small battery causes lower voltage with any loads applied compared to a normal-sized battery, for which it is probably calibrated. This morning, ODB2 reads 60%, and my BM6 reads 47%. I use SOC from the BM6 for trend analysis.
Mike G
N. AL, USA
There is even a service tool routine in FDRS for the BCM module to correct the 12V battery charging settings back to what they're supposed to be in the event that somebody (using FORScan, I assume) has tweaked the settings inappropriately. It's listed under the Programmable Settings tab in FDRS.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
BMS system generslly should not care about the battery capacity. Its only job is to get it to a full state of charge.
Agreed but if it doesn’t know the capacity it canā€˜t give you a percentage SOC. It will only be accurate at 100%.
RLXXI
3rd rock
Automotive Technician
I've always used voltage never soc when determining battery health.
Adventureboy
Adventureboy
Agree, voltage alone is way more useful than SOC alone, but they are related, and voltage is only meaningful if you know the SOC and the current draw at the point in time when you take the voltage reading.
  • 12.7v doesn't tell you if it has the capacity to get through the day. This is why so many folks have batteries that test ok on inexpensive testers, but the truck still gives them messages every day. Replacing the battery solves the problem.
  • 11.8v doesn't tell you if the battery is bad or just discharged to 30% SOC, or handling amperage for a dozen live modules with an update in progress. I've seen updates draw down to 11.0v on a healthy battery.
  • 7v is probably pretty bad, although I've seen this a couple of years ago on the wife's MME on a fully discharged AGM (HVBJB failure). The battery recovered and is still operating 2 years later.
RLXXI
3rd rock
Load test is the only way in my professional opinion, I've used one of these at home and the shop going past 40 years now.
mr.Magoo
2022 Lariat ER, AMB
I'm interested in what you've seen on this front.
This is pretty representative of what I see regularly.
While charging it's typically around 14.5 - 15V, once the battery is almost fully charged (+90% SoC) it goes into the "float" stage and the voltage is reduced to 13.5V.
Ford F-150 Lightning 12V Battery replacement with H4 1773357686655-f
Adventureboy
Adventureboy
That's the proper way to charge an AGM. Mine is pegged at 15v measured at the battery posts. 7-hour HVB charge cycle a few days ago - 15v the whole time. Maybe this is why my Lightning is hard on LVBs.
What do you use to capture the data?
When you get a minute, can you tell me what your Battery Monitor Sensor part number is? I had mine replaced under the CSP, and have ML3T-10C652-BA. Perhaps it is simply a bad one or they replaced it with the wrong one.
Adventureboy
Adventureboy
mr.Magoo
2022 Lariat ER, AMB
That's quite a nice setup. Is your OBD polling set up through the Pi? I'm guessing you only log data while running, or did you solve the problem with OBD polling, activating the modules while OFF?
Thanks !
Yes, I'm logging whenever the truck is on or charging (it's still kind of 'on" at that point so...).
The modules are sleeping when the truck is off so you won't get a reply from them and I've tried them all at this point hoping to find something useful. If you do poll the same module often enough, like 3-10 times within a few seconds (I forget the actual number, but it's something like that) it will actually wake up the modules and you can request data - but - it's not like the truck turned on, so you have no power supply (the DC/DC) so now you start to drain the LVB battery and it drains pretty fast - so in the end it's not really worth it.
Kansan
Wayne
2024 Flash
Civil Engineer
The BM300 is the one you want. Don’t need SOC from the Bluetooth monitor. The BM200 is only going to give accurate SOC when all the modules are fully shut down - no key fob nearby, no door opening for a half hour, ignition off for a half hour, etc.
I see you have a BT (Ancel?) battery monitor. I've had my Ancel BM200 for almost 3 weeks and it still gives extremely incorrect SOC readings compared with my OBD reader. Anyone else have that monitor behavior? Is mine malfunctioning or does it take a very long time to equilibrate?
That monitor can only give you an accurate SOC based on voltage. And it would need to be when all modules are completely off - so ignition off for a half hour, key fob out of range for a half hour, no doors opened for a half hour, etc. It's using voltage and a table of voltage to SOC.
Airforce
Richard
North Carolina
Ford Lighting F150
I don’t have any hard evidence but I don’t believe the BMS is only concerned with voltage. I believe it is a ā€fuel gaugeā€ type of BMS and is monitoring the current in and out of the battery. If it only cared about the voltage it would just connect to the positive lead and would not need to be in series with the current path. That is why it is important to always connect a charger downstream of the BMS. A voltage only BMS would not care where you connected.
Thinking about it some more it still probably doesn’t matter but the SOC number will probably be wrong. The BMS is calibrated to a full 35 Ah battery so if for example you have drawn 3.5 Ah from the H3 it will show 90%. If you have an H4 your actual SOC after drawing 3.5 Ah will be 93%. You will always read lower than your actual SOC which should actually help keep it charged.
Is a LVB Voltage Reading of 12.47 considered Normal on a truck sitting overnight?
mr.Magoo
2022 Lariat ER, AMB
Personally I'd say that's pretty normal.
Both my trucks LVB and my backup battery (also 30Ah AGM) are both at 12.5V right now and they've been sitting for about a day.
