Powertrain Malfunction/ Reduced Power
abcut973
Anthony
Denham Springs
Hi all. I guess my time as come. I got the powertrain malfunction reduced power error on March 10. Took it to the dealer on March 16 and was diagnosed with a dead cell. Since then, we've been waiting on part number NL3Z-10D672-E. As of Friday - no ETA on the part and no tracking number. This doesn't seem normal and I'm concerned this is only a sign of things to come with the Lightning now that it's been cancelled.
Which part of the country are you?
abcut973
Anthony
Denham Springs
I'm in the DFW area.
Ok. When i got my module replaced I was in austin TX. The part took 3 weeks to arrive. They ordered it second week of January. Got my truck back 1st week of Feb.
Hopefully yours is on its way...
GoodSam
Good
occupying space
Horrible amount of service time, which I experienced as well as dealer lone tech was working on a Mach-E slowly.
What is the build date for your Lariat (see top of sticker in driver's door area), mileage, and extended range? See my signature for spreadsheet of other victims. We were hoping that only 2022-23 models would suffer from bad HV battery modules, but a number of 24's are caught as well.
smartace414
Smart
TX
2024 Lightning Lariat
Hello GoodSam. I have spent way too much time analyzing your spreadsheet. Thank you for taking the time to put that together and making it available for the community. As soon as I get to see my truck in person again, I will report back. I sure do miss her!
Which dealer are you using? Several of us in DFW have had a module replaced.
PAndaemonium
MY23 Ford Lightning XLT ER
Warmer weather and started getting the error almost daily when the AC kicks on. Any tips on what to tell the dealer when I go in for service?
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_3598
PAndaemonium
Just checked diagnostic codes
P0DE9 Coolant valve
C0604 Air dam system fault
Did you notice the fault when the A/C kicked on?
MJB28
DE
2022 F150 Lightning, 2020 Harley Livewire
No, but I didn't need to use AC. Mine was the coolant valve. I have extended warranty so it was only $100
smartace414
Smart
TX
Truck returned after a whooping 64 days out of service. Build date 6/2024, 7736 miles, with extended range battery pack. I hope this is the last issue and the truck is a tank from here on out.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Thanks for the update. You really had a long dragged out fix of what should have been a 2 week issue. Good Luck from now on out.
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
I got the error three times in the last month but it’s been combined with a 1-pedal fault. Rebooting the car has fixed it. Should I have it looked at by the dealer?
