Charging at RV sites
MidAtlanticLightningClub
F-150 Lightning Lariat ER
Of course.
See my the attached pix below.
Very interesting that this seems to be available in Sync 4 (12” landscape screen) but not Sync 4A (15.5” portrait screen).
Has anyone seen if this is an option that FORScan can enable in Sync 4A?
21st Century Truck
Martin
Hmmm... I seem to remember although it's been about two years now, that my Premium trim Mach E's 15-inch screen did have this feature as well. My memory might be in error here though...
As the APIM is the APIM, it would seem that the toggle button should indeed be activatable through FORScan. Perhaps tech wizards like Jesse - Infotainment can weigh in...
I don’t recall ever seeing this on my Mach-E or my Lightning. Of course, my memory could be worse than yours!
I've definitely never seen it on my Mach E. The Mach E is also Sync 4A with the 15.5" portrait screen. It also doesn't have an "access" tab.
Maineiac12
Iowa
@Jesse-Infotainment any idea if it’s possible to add this option to the 15” screen in the software?
Here’s a post showing the button on a Mach-E. In 2022.
https://www.macheforum.com/site/thr...-no-longer-indicates-charge.18241/post-433339
The following post notes it was removed in early 2023. That may have been the major Sync overhaul that got rid of the large tile option.
21st Century Truck
Martin
bthanos
2023 F150 Lightning Platinum
System Architecture (retired)
Pinnacles campground is privately run. The heat there gets insane in summers so high current charging represents fire risk, ( and reduced profit margin of course). There are chargers you can get to in the area I would think. Anyway your lightning might thank you for not charging at 105F…
