25C69 Recall - Ford Recalls 2022-2026 F-150 Lightning Over Rollaway Risk
IanDanby
Ian
Long Beach NY
2025 Lightning Flash
Web developer
After performing the recall for 25C69 my battery failed and they replaced it. Then the check engine light came on and my truck was in the shop for 3 weeks! Here is what they did to get it fixed (directly from the invoice)
Concern CUSTOMER STATES WRENCH LIGHT IS ON AFTER FSA 25C69 WAS
PERFORMED
Cause VERIFY CONCERN DTC PRESENT P2DA4 P0AA6 P1A10 CONTACT TECH
SUPPORT FOR GUIDANCE TECH SUPPORT STATED PERFORM RECOVERY
AND PMI OF SOBDMC. SUCCESS. TEST DRIVE VEHICLE WRENCH LIGHT
CAME BACK OK DTC P2DA4 AND U0594 PRESENT IN SOBDMC PERFORMED
PPT AI 1 TO AI 13 ENDED IN SYTEM WORKING CORRECTLY CONTACT
TECH SUPPORT TOLD TO CHEK FUSE FOR CABIN HEATER AT HV
TERMINALS, CONNECTORS FOR WATER INTRUSION ALL OK. PERFORM
PPT AI AGAIN THIS TIME AFTER RUNNING A/C AN HEAT FOR 20 MINUTES
EACH AI1 YES AI2 YES AI3 YES AI12 YES AI 13 YES ENDED IN SYSTEM
WORKING CORRECTLY P0AA6 APPEARED IN BECM PPT U PERFORMED
THE HIGH VOLTAGE SYSTEN ISOLATION FAULT ROUTINE AND ENDED
WITH DTC NOT CURRENT TECH SUPPORT INSTRUCTED TO DISCONNECT
ACCM AND CABIN HEATER SEPERATLY WHILE DRIVING VEHICLE TO
ISOLATE CONCERN. FAULT SET WITH ACCM CONNECTED INSPECTED
WIRES AND CONNECTIONS OK CHECK FOR CORRECT COMPRESSOR OIL
OK
Correction
R&R ACCM AS PER INSTRUCTIONS RECOVER 1.163GK TEST DROVE
VEHICLE WRENCH LIGHT CAME BACK ON P2DA4 AND U0594 IN SOBDMC.
CONTACT TECH SUPPORT AND FSE TOLD TO REPLACE HEAT PUMP. R&R
CABIN COOLABT HEATER AS PER INSTRUCTIONS IN WSM RESET DTC
TEST DRIVE VEHICLE NO DTC PRESENT
MichaelCA
'22 Lighting ER, '22 Tesla Model 3, '16 Mustang GT
PERFORMED
OK
Correction
Looks like it was a bad heat pump.
sfringer
Scott
NC
I got a cold call today from my local dealership indicating my '23 Lightning had an outstanding recall (25C69) that qualified for mobile service. If I was interested they would be happy to schedule me for the service. So I'm on the books for next Monday afternoon for a mobile service call at the house to apply the update.
Lucky duck, I asked if Tasca did mobile service, NOPE, bring it in and should be done ~3 to 4 hours later, suspecting the long time frame in case they need to swap the tailgate light bar after reprogramming the parking module.
sfringer
Scott
NC
That's a bummer. I've had good previous experience with this mobile service team. And when mobile service wasn't able to cover the work, they came and picked up my truck and brought it back when completed.
bydabeach
NJ
Lighting Lariat ER; Volvo S60 Recharge
Scheduled my 20,000 mile service and the software update for 25C69 Parking issue. Truck picked up by Ford valet at 9:30 a.m. 3:30 p.m. I get a call from service advisor that the update is STILL downloading, and they have to keep it overnight. I have a 2022 ER Lariat. WTF? Am I cooked? I need my truck and can't afford to have it out of commission for the weekend. Anybody experience this where a software update takes more than an entire day?
The Weatherman
Dean
South Central KY
I just had my 2022 in for the recall and yes it took just over three hours from when they started the update before I was out of there.
I got my truck back Friday afternoon, all seems well with no problems or lost settings.
They have no way to turn off the 30k service reminder, and blame the Ford App for flawed data.
MountainAlive
Massachusetts, USA
It’s possible they didn’t get to your truck until like 2pm and realized it was 5 o’clock somewhere and needed to start the weekend.
bydabeach
NJ
Yeah but how long should this take?
astrand1
Alex
Studio truck driver
My dealer did the mobile service for my 23 Lariat in my driveway. This update and I think he said 2 other ones was done in under an hour. Something’s not right with yours or your dealer fucked something up.
halfbakedenchilada
Intermountain West
2024 Lariat ER
Wild. Just did mine and it took 30 min. 2024, not sure that matters.
queuewho
Western PA
22 F150 Lightning Lariat SR
My local dealer sends out mailers about how they have mobile service, and if you call and ask for it, they don't know anything about it.
