B177y
Olympic Peninsula, WA
What you’re explaining on the usb flipping is what I did.
On the resistor and lightning and comma symbols, I’m not seeing those. It’s enclosed within the 3d printed case as I received it from bluepilot. Can you elaborate on that one?
i confirmed it is on the black plug, 2 plugs up from the fiber optic lines (not the gray one).
Glad Ajz got it sorted.
The docks with the integrated coupler are already oriented correctly so no need to worry about that. The standalone couplers have marks to orient them in the correct direction.
Looks like a new USB and you be on the road 👍
HornetRaider
Abe
DFW
2023 Lariat ER
Thanks for sending him the signal!
Ajzride
Alan
Houston
Eng
wow. Thank you for the suggestion. Tried the short usb, turned the truck on, and it immediately turned the camera on and asked me to start driving.
What usb do you recommend for the long one to fix this issue?
While you are waiting on the new USB cable you could test the Comma4 without the dock and just plug the long USB straight into the C4.. I use a USB testor on all the components before I assemble the dock, but since I don't have the bluepilot C4 at the moment (Anthony has ours), I can't actually test the assembly.
HornetRaider
Abe
DFW
2023 Lariat ER
I sent the required specs of the cable to our company's IT. He said he has a cable that fits the bill. Going to try it at lunch direct to the C4 to confirm, then to the dock, and if that works, I'll go through the trouble of tucking the wire again.
Shmoe
2024 F-150 Lightning Lariat, 2025 Rivian R1S, Sold-2020 Tesla Model 3 SR+
They're super finicky. If it doesn't work go with ajzride's and you'll be gold -- That's what happened to me.
HornetRaider
Abe
DFW
2023 Lariat ER
Didn't work, unfortunately. I ordered the cable ajzride recommended. Should be in tomorrow.
BluesClues
2022 f150 lightning sr lariat
HornetRaider
Abe
DFW
2023 Lariat ER
The new usb cable came in. When I plug it directly into the c4, it works but doesn’t recognize the car. When I plug it into the dock with integrated resistor, I get the same issue. Says start the car while car is started..
Ajzride
Alan
Houston
Eng
okay, let’s not bog down the forum troubleshooting the dock. You should
have an email where I sent you tracking information. Reply to that and we can work through it.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
HornetRaider
Abe
DFW
2023 Lariat ER
I finally got up and running. Really impressed with the WD-40 model. Only thing I've changed is the -.05 lane offset. Need to plug in the rest of the recommended settings.
Is it just me, or are the attention alerts way more invasive on the comma than the native Ford blue cruise? Everything I was reading before purchase said the Comma was more relaxed, but I'm finding the opposite to be true.
