BluesClues
2022 f150 lightning sr lariat
HornetRaider
Abe
DFW
2023 Lariat ER
While you are waiting on the new USB cable you could test the Comma4 without the dock and just plug the long USB straight into the C4.. I use a USB testor on all the components before I assemble the dock, but since I don't have the bluepilot C4 at the moment (Anthony has ours), I can't actually test the assembly.
The new usb cable came in. When I plug it directly into the c4, it works but doesn’t recognize the car. When I plug it into the dock with integrated resistor, I get the same issue. Says start the car while car is started..
Ajzride
Alan
Houston
Eng
okay, let’s not bog down the forum troubleshooting the dock. You should
have an email where I sent you tracking information. Reply to that and we can work through it.
Ted23Lightning
Ted
Mobile ADAS Technician
BluesClues
is this angle based turning in our future?
(in case others don't track other vehicles: )
HornetRaider
Abe
DFW
2023 Lariat ER
I finally got up and running. Really impressed with the WD-40 model. Only thing I've changed is the -.05 lane offset. Need to plug in the rest of the recommended settings.
Is it just me, or are the attention alerts way more invasive on the comma than the native Ford blue cruise? Everything I was reading before purchase said the Comma was more relaxed, but I'm finding the opposite to be true.
HunterHan
Curt
New York
2024 Ford Lightning Lariat ER
I found the Ford native to be way worse. I’m running BP 6.0 and the Liquid Glass model. Chat GPT was helpful dialing in and explaining exactly what each setting is and how it affects the vehicle. Good luck and enjoy!
BluesClues
it is funny that most of the LLMs reference LCD (i didnt have good luck)
Ajzride
Alan
Houston
Eng
A) bp-3.0 was angle based, no one liked it. We are working on a complete rewrite of it.
B) That is such BS. @UncleTony Did a ton of the hard work on Angle, and Lukas is the hero.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
That video was about the co-op steering add on since angle by default disengages when you try to take over. But, I would be lying if I said I wasn't glad to get out of Rivian dev due to the community dynamics :). I was lucky to get added into the description every so often.
Reactions: EVO
HornetRaider
Abe
DFW
2023 Lariat ER
Voted. Is there a world where comma can integrate with a mapped destination, linked with this device, to get closer to self driving?
UncleTony
Tony
They are supposedly working on P2P, but not sure on the expected timeline. Guessing it would require the EGPU, but that is just a guess.
Ajzride
Alan
Houston
Eng
They used to have this, they called it Navigate On Openpilot (NOO). They pulled it because it worked too poorly. No telling when it will come back.
