Priority Update - BCM-24.5.1 - Convenient Frunk Closing
ryun
Earth
Also got this update. My muscle memory always locks my truck when I exit even if the frunk is open so I'm glad I won't have to fumble for the keys just to close it anymore.
jetfixr1
Manny
Atlanta
Can someone give a quick summary of what this update provides? Some people report no WAL. Ive been out of the loop on this one.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
I just recieved this update yesterday. Forgive the stupid sounding question but I don't quite understand the Convenient Frunk Closing meaning. It says it closes now when truck is locked. I think my truck did that anyway. Am I overlooking something,?
Thanks.
potato
BC, Canada
2023 F150 Lightning XLT ER
Thanks.
It would not close with the button on the frunk itself, on XLT at least. You would have to use the fob or the keypad instead. Obviously that's what you would want for *opening*, for security reasons, but closing? Makes no sense.
Honestly that was one of the main "WTF were they thinking" complaints I had about the software, so it's really nice if it's fixed.
Jim Lewis
San Antonio, TX
I got this update in the early AM as I was testing backup power transfer with the Home Integration System. I learned an interesting thing. Backup power transfer (BPT) was not working when it had been just a little earlier for me. I decided to get in the truck and try a manual BPT via the Intelligent Backup Power applet on my SYNC screen. I then noticed that BCM 24.51 had downloaded and was ready to run during my next allowed update window. Hmm, I thought, maybe the downloading was what screwed up BPT that I had been initiating via pressing the UNLOCK button on the charging port and unplugging and replugging the charger head. When I launched the IBP app, I saw that I was in manual mode, which would have blocked BPT automatically via the UNLOCK trick. I figured I just forgot to switch out of manual mode from previous experiments. But in discussing my BPT experiments with ChatGPT 5, it mentioned that Ford OTA updates that need to go into Inhibit Mode, as 24.51 does, typically turn off automatic BPT, so the truck doesn't decide to do a BPT in the middle of an update. ChatGPT claimed that turning off automatic BPT would occur with the download, not just during the update. It also claimed that glitches in the online portal, energy.ford.com, that Ford created after removing BPT functionality from FordPass, can also sometimes turn off automatic BPT in the truck. It suggested that I periodically check the BPT status (automatic vs. manual) in my truck, especially before an expected incoming storm. I don't know yet if the above is an AI hallucination, but I plan to look into it further. With my grid power cut in my ongoing test at the time, when I switched from manual mode to automatic mode via the IBP app on my SYNC screen, BPT initiated automatically within seconds. It's interesting to think that a deliberate manual to automatic mode BPT switch might be another way to "prime" the HIS system to actually work. YMMV.
It's really heinous that Ford removed BPT functionality from FordPass and that there's no convenient way, without getting in and turning on your truck, to find out whether the truck is in automatic or manual transfer mode. As usual, the Ford servers powering energy.ford.com are very glitchy and slow to update status. Several minutes after I've cut power to the house, those servers may still report the truck is on the grid and ready to charge, etc. Ford really needs to get with it and deliver a higher standard of performance in its products.
BTW, a weird side effect for me of the Convenient Frunk Closing update is that my Welcome Lightning, which has been OFF ~since I got my truck in 2023, got turned back on somehow.
I <3 My Lightning
@Jim Lewis
Yes, same thing with the welcome lighting being reactivated on mine and it also changed the delay of headlights turning off... Audio eq settings was also reset to default... It defaulted to main cluster menu selected features, (trip 1, brake coach, calm screen), and it also reset main cluster brightness level.
Hey @Ford Motor Company what would be cool is your notes should include all the settings reset easter eggs you also included with an OTA.
Ford Motor Company
Official Ford Account
F-150 Lightning
@Jim Lewis
For sure. I'll pass these along to the OTA/Software team so they are aware.
Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
received this update but NO wal. ive tried with the fob. with the paak. nothing. i actually looked forward to wal. its convenient for me.
When mine installed, the function was turned off, have you checked the settings?
Storm Breaker
Norm
truck driver
After update bcm-24.5.1 installed i checked in settings. no toggles. this is my most recent update that i got 2 days ago. ive tested it many different ways and my doors never lock.
Ford Motor Company
F-150 Lightning
It might still be in the process of rolling out to you.
I also received the BCM-24.5.1 'frunk' update several days ago. Now I actually CAN NOT close the Frunk with the exterior button, whether the truck is locked, or not... and also CAN NOT open it, from the exterior button, either way...
One other phenomenon: My Ford Pass App will allow me to LOCK doors, remotely, but when I press UNLOCK from the app, now ONLY the driver door unlocks - formerly ALL doors unlocked.
I <3 My Lightning
Did you check the lock settings and is it set to for drivers door only?...there is a remote unlock setting for driver only or all doors.
