FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62
This update appears in Ford Pass with the caution symbol, I've already completed a power cycling of the FCSP, the warning should go away in the next few days.
I'm not aware of what has been improved, but hopefully it helps the HIS system users
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 1693163911533
The Charge Station Pro setup utility shows this confirming the update has posted:
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 1693164021468
BTW: Credit @4Reeley and @BSull for the heads up about this recent change in the following thread
F150ROD
U.S. Navy Retired
It would be nice if Ford posted improvements. Like can it now charge a Tesla with the new CCS adapter
Ffxdude
22 Lightning
Good find folks! I’m showing the update pending too. My fingers are crossed it fixes my overheating issues.
if I remember correctly it won’t push the update if the truck is connected to the charger right?
jerock
Jerry
Kansas
F150 Lightning
That is correct. I was told by a Ford Rep that it must be unplugged and it updates between 12 am and 4 am.
techmatters
Pennsylvania, USA
'23 Lightning Lariat ER Antimatter Blue
It seems like FordPass is just horrible at syncing information. I either saw it in this forum or FB group that the FCSP software version shows it's updated in the ChargeStationPro app. So I checked mine and my FordPass app has said I was stuck on the typical 2.112.64 "Stock" software for over a week, but the ChargeStationPro app shows its software was updated to the latest. Now this new software is released and my FordPass app shows an update pending for the new software, but my ChargeStationPro app shows the software as updated already. The ChargeStationPro app also shows a few extra #'s (2.112.91.:2.149:1.32:0.62:1.53)
Super disappointed in how badly software updates are handled with Ford. I upgraded a 2019 Sync 3 to get the Sync 4 with this OTA updates that were supposed to be so great. Now Ford CEO says "software is hard" and they have a lot of work to do, this isn't their first foray into software, it's such a cop out excuse for over promising and under delivering.
4Reeley
PA
Lariat
@techmatters it may sound like an excuse, but most end users outside of this forum won't go back to the FCSP Setup app once the unit is connected and set up. I don't think Ford intended for users to be comparing the two, only viewing things on Fordpass. Maybe that's why there's a delay between the syncing of the two apps.
The FCSP Setup app doesn’t display it all on that screen. But if you click on it, a popup will display the whole string. See first post above. Note the last two numbers will be reversed though. Shows 0.62:1.53 instead of 1.53:0.62. :unsure: Don't know what each version number represents but each one has steadily increased on my FSCP.
lakeguy55
New Hampshire
2023 Lightning Lariat, 2011 F-150, 98 Expedition
My FCSP has been installed for about a month. Strong wifi signal, always connected, but firmware would never update from factory version. Until this weekend. Sometime over the weekend, the latest version installed. Finallly!
CNote
Ford Explorer
Thank you for posting this! My truck is plugged in every night, so I wouldn't have received the update. :-/
ExCivilian
'05 RAM 2500 5.9L Cummins; '22 Lariat ER
Mine is at this version and still has a pending update.
That's been the case for me and happened in the last update cycle, eventually it will go away.
