Frunk Not Closing ?
The Weatherman
Dean
South Central KY
I’m I the only one having a periodic issue with Frunk not operating correctly.
It seems to happen more often when the truck is on slightly unleveled ground, although it has happened when it was in the garage on level ground, but the lid had been open for a while.
When you press the button to close the lid the trucks peeps a couple of times and the lid never moves. I have only been able to manually force the lid closed after it fails to close on its own.
Anyone body else and do you have any suggestions?
I recall old posts about the frunk forgetting it's position after being left open a long period of time, solution is to manually close it, then retry opening & closing via dash button or app, it should return to normal after this.
laselvasurf
Phil
Santa Cruz CA
You may already know this but, I was getting frustrated with it not closing with the button until I realized that when the truck is locked, the button will not work. I assume this is to prevent you from locking the keys in the frunk, but I find it a bit annoying.
But you could lock your keys in the frunk if the truck isn’t locked. Aren’t you still stuck? Or will the truck start with keys in the frunk?
The truck should NOT start with the fob in the frunk. It's supposed to sense it IN THE CAB.
The Weatherman
The Weatherman
Dean
South Central KY
That sounds like a theory needing testing. Watch ing.
Amps
Mid-Atlantic
Bolt
As noted, manually closing the frunk will sometimes seemingly get it out of cycle. When the button beeps after a single push of the rubber button and won't close the frunk, to me, it sometimes seems like an "are you sure you want to close this thing?" beep. Usually, it will close after another press of the rubber button. After manually closing the frunk and getting it out of sequence, I stopped doing it and used the button inside the truck. Usually, I don't have the tremonsterous fob with me to try that button. The button inside the truck has never failed.
The Weatherman
The Weatherman
Dean
South Central KY
Thanks for the input. I have tried that on a number of occasion and found that after it signals its failure, nothing seems to work to get it to close on its own.
I will bring it with my service department on my next visit to the dealership.
All good information. Thanks everyone.
Exactly my thoughts. Which makes the theory about being unable to close when locked suspect.
So I just tested. Open frunk. Lock the truck. Attempt to close the frunk using the button on the frunk. It closed normally. So if the frunk won’t close, it not because the truck is locked. It’s either been left open too long, or something’s broken.
ivan256
Massachusetts
2022 Lightning Lariat ER
Probably doesn’t apply here, but the frunk won’t operate if the truck is in gear either. If you shift while it’s closing, it will stop.
Yes it does. I was picking up food once. Opened the frunk and had them place it in there. Hit the button to close and since I didn’t want to hold up the line behind me, I shifted to D just before it latched. Really stupid design IMO.
laselvasurf
Phil
Santa Cruz CA
You could not because you can always push the button in the cab or open the frunk, or use the manual release.
laselvasurf
Phil
Santa Cruz CA
That's interesting. Mine operates differently.
Try this as well: With your truck locked, use the key to open the frunk, then try and close it with the button. My button absolutely will not work in that scenario until unlock the truck, or use the key fob button to close the frunk.
All that to say, I'm wondering if different trim levels have different programming. My truck is an XLT and does not have passive entry.
The Weatherman
The Weatherman
Dean
South Central KY
True…I didn’t consider that.
Mine still opens when using that sequence.
Trim level difference is a definite possibility.
