How can I remove ice from inside the truck’s charge cord receptacle
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2023 Tesla MY, 1941 Lincoln V12
I need help.
No problem the first 2 winters but now I can’t plug in far enough to latch the plug and charge the truck. I did just order the pricy Canadian charge port cover but the horse has already been stolen. No garage and the weather has been and is forecast to remain 0 to 20 with more snow almost daily and worst of all, very high wind.
I do carefully use a heat gun but is there a different way? For example what would happen if I squirt windshield washer fluid rated for 30 degrees below into where the plug goes? Maybe even preheated washer fluid?
Other ideas?
I would stick with a careful use of the heat gun, then use compressed air-can to blast out the melted ice/water.
topofsuperior
steve
2023 lightning Lariat
I ran into this recently. I used a thin screw driver to scrape the snow and tap it out. Worked so I didn’t get out the heat gun yet. Will be watching this thread with interest
How is the snow getting in there? I live in a cold climate and have never had any issues. I can envision a situation where you might not be able to close the charge port door but I don't understand how ice and/or snow gets into the actual charge port.
sotek2345
Engineering Manager
I would recommend a blow dryer instead of a heat gun - less chance of damaging the port.
Source: Guy who has melted too many important plastic things with a heat gun.
No, you should not put in washer fluid. Use a hair dryer to defrost, and an air hose or compressed air to blow out the liquid if you can't simply mop it up with a rag. Blow dry until nothing remains.
So far this has happened to me once in 3 winters. Parked outside all the time and no cover. I use the fcsp.
I used my wife's hair dryer, it worked incredibly well. Not only did it melt the ice, the wind force generated by it helped clear anything out, way better than a heat gun.
Luckily the truck has outlets to spare if you're not near the house. Pro tip, keep an extension cord in your subfrunk for emergency use of electrical appliances.
This ^^^^
rickersondon
Don
Manassas VA
Ford lighting 2023
Try one of those EV port covers, the magnet will not stick but you can bend it to keep most of the water out.
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
A hair dryer would melt it easily, then blow out the water with air or dab it out with Q-tips. Then get one of these!
Ford F-150 Lightning How can I remove ice from inside the truck’s charge cord receptacle IMG_1175
RickKeen
Minnesota
F150L SR Pro
sw engineering manager,
Compressed air at above-freezing temp out of a small nozzle will melt small amounts of ice and blow the water out quickly. Even a small temp above-freezing at high enough flow will cut through the ice.
(note that the air has to be above-freezing, so needs to come from a compressor tank in a heated garage or shop).
Boomerboy
2024 F150 Lightning Flash
Get a faucet cover from home depot. They are under $4. You need to trim to fit around the charger cord. I tried the cover available from ford parts / accessories and it was worthless. My $4 faucet cover works well.
Ford F-150 Lightning How can I remove ice from inside the truck’s charge cord receptacle Imag
K6CCC
Glendora, Calif.
Move to someplace that does not get that cold. Sorry, couldn't resist - I don't do snow...
RickKeen
Minnesota
F150L SR Pro
A high-intensity work lamp with an incandescent bulb may throw enough gentle IR heat to melt things slowly. The kind with the 150W-500W Halogen bulbs. Like a heat lamp. Something with a clamp or a stand could maybe be setup easily.
Ford F-150 Lightning How can I remove ice from inside the truck’s charge cord receptacle 1739982885083-ov
LED Lamps of course will not throw enough heat.
