No Preconditioning for over a week
Amps
Mid-Atlantic
Bolt
Tried the brake trick when I parked last night and I had high hopes for this morning. Alas - no preconditioning. Would have been real nice too since I had frosted over windows.
When it does work, do you have the heated steering wheel glitch where it won't heat again after pre-conditioning?
This may seem like a strange thing to do but try stepping on and holding the brake peddle when shutting down the truck. This seems to make truck remember last settings. I have no idea why.
I tried that lats night - I had high hopes, but it didn't work again this morning.
Yes I do.
CRAIGC540
Craig
Moreno valley
Technician
Does pre conditioning only work when plugged into your charger?
Mine works fine when plugged in, but i think when not plugged in it starts with my last settings.
When you select the while un plugged switch to ON, the cabin preheating is all you get while unplugged.
OK - haven't posted for a bit.
Friday afternoon - nothing (plugged in)
Weekend - none scheduled
Monday (12/12) morning - nothing (plugged).
I also get no messages in Fordpass when it fails.
Woohoo. It did work this afternoon. Not plugged in. No notification in Fordpass however.
Worked again this morning while plugged in (knock on wood). Not sure if I appeased the correct deity or it is just a fluke.
data003
Maine
2022 F-150 Lightning Lariat ER (Totaled), 2025 F-150 Lightning Flash ER
Mine started the other day at 9pm, when I had it set for 7:10am. I finally gave up and turned it off. I was lucky if it worked 1 out of the 5 days I had it enabled for.
White_Lightnin_87
Ryan
Nashville
2022 F-150 Lightning, 2021 Q7, 1966 Ford Mustang
CPA
I took delivery of my 22 ER Lariat in October and the preconditioning has worked perfectly....up until a couple of weeks ago - I woke up and it did not precondition, but the next day it did so I didn't think anything of it. Today was the second day in a row that it has not preconditioned at home plugged in. Ford has to be aware of this, right?
I deleted all the precondition times in the truck and reconfigured them. Hopefully that works or this update they are about to push out soon will fix it. I am still on 3.5.4 just FYI.
F150ROD
U.S. Navy Retired
Mine preconditions 90% of the time. Today was one of the 10% of the time when it didn’t and it was cold…. I needed it @Ford Motor Company
Just for kicks, while the truck is not plugged into your EVSE, power off the EVSE at the breaker, leave it off for ~5 minutes, then power on. Let it bootup and process any updates (if it's smart and network connected), hopefully your next scheduled pre-conditioning will work.
Sc954rr
Scott
NJ
F-150 Lightning, Volvo XC90
Same here, mine has worked for weeks when it was 30°F-40°F in the mornings but today when it was 19°F and heavy frost there was no pre-conditioning happening. The only thing that changed was there is a software update waiting to go that keeps failing, so I am wondering if that had something to do with it getting messed up. The truck was plugged in all night and charged to 90% as usual.
F150ROD
U.S. Navy Retired
It might be, but I have no software update in sight. Only an Electrical failure message. I already booked an appointment for service
