Pro Trailer Hitch Assist via OTA update for MY22?
KingStraasha
Kevin
Dayton, OH
2023 F-150 Lightning Lariat ER, Antimatter Blue
I do believe I received the BCM and WAL updates. The last two that I received are: SYNC-25.2.1.6.5 and the BC 1.4 update. If someone can check, my VIN is 1FTVW1EV7PWG*****.
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Platinum
Send me last of the vin
MountainAlive
Massachusetts, USA
If you have a 2023 I don’t think you can have smart hitch. I believe it requires the onboard scales and 2023’’s didn’t get that due to chip shortage that year. But it does seem like 2022’s would be possible via software.
theaustinite
Ben
Smart Hitch and scales are different than the Hitch Assist, I believe. Pro Trailer Hitch Assist just backs the hitch up to the trailer automatically. It should be available with the tow Technology package and Pro Trailer Backup Assist.
Jesse-Infotainment
Jesse
Dallas
A note to those that are having issues getting this to work.. you can NOT have a 1578 DTC in the IPMA.. you have to have a good calibration in order to have AUTO hitch to work.
If you have the 1578 DTC and are happy with the stitching of the cameras
write
706-26-19
XXXX 8XXX XXxx
It should make the code not current.. don't clear it yet until you drive it
theaustinite
Ben
write
706-26-19
XXXX 8XXX XXxx
This! Mine is working now. Thank you!
Blochead21
PA
Black 22 XLT 311pkg
write
706-26-19
XXXX 8XXX XXxx
Jesse, so what’s actually needed for this to work? Do we need to have the tow tech pkg? Or just make the Forscan changes?
Jesse-Infotainment
Jesse
Dallas
As long as you have a Trailer brake module.. You can make the as build changes and enable Auto hitch. The issue was some guys were having issues with it erroring out. THey had 1578 DTC in teh IPMA> That has to be gone for the AUto hitch to work.>
Yesterday, I needed to get the Snow Blower out of my trailer where it lives through the non winter months.
Installed the hitch, lined up my truck and tapped the Pro Trailer button to see if it would give me assistance, no luck, only wanted to have me do a calibration drive, (ie. introduce a new trailer profile) since I had previously deleted this trailers profile in previous debugging tests.
I suspect that even when I complete the trailer training routine that it'll not offer to do a hitch assist routine, it'll only do the back-up assist process for parking an already attached trailer.
Maybe there are manual updates I could make with FDRS and the recently acquired programming tool??
Ford F-150 Lightning Pro Trailer Hitch Assist via OTA update for MY22? 1764505512047-c9
So this would be a Forscan tweak ??
Jesse-Infotainment
Jesse
Dallas
I'd rather @Ford Motor Company prepare an OTA to deliver the promised update to MY22 Lightnings so I can avoid FORSCAN.
Jesse-Infotainment
Jesse
Dallas
Possibly we could make a Genie to make the changes if people would be interested in that.. rather than doing it via forscan.
The auto hitch requires you also have the trailer brake module. So you would have to have added it if your truck didnt have it.
