Status
Not open for further replies.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Does it matter how often I charge to 85% or 90%? For example, I drive not more than 20-30 miles each week day. If I’m at 85% on Monday morning, then at 75% Mon evening, should I charge back up to 85% each night? Or charge to 85% Sunday night and let it get down to maybe 20% or so by Friday evening, then charge back up to 85% for the weekend?
If I charged every night, it would go from probably 75% to 85% every night. And would only go lower than 75% on the weekends or on trips.
Your daily charging strategy would be very good for you.
For me, I also drive no more than 30 miles a day but I charge once a week or every 10 days.
In order to charge every 7-10 days, my charging strategy is to charge to 100% on L2.
L2 charging is slow enough that the cells won't heat up and since it's once a week, 100% is not harmful as I drive it daily.
jlwillia6
‘14 Silverado, ‘23 Lightning Lariat ER (ordered)
Thanks for all the feedback everyone! Cabin temperature isn’t an issue for me when I charge overnight as it’s parked in my heated garage that never gets below about 60F.
It sounds like I’ll just charge every 3-5 days or when it’s at about 30% state of charge on my Level 2, 48A charger.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
when it was out, it was out. Tesla will pick you up on a flatbed and take you to the nearest charger for free when you run out of juice, which in my case was a half-block to my garage - the driver was masterful at placing the car directly into the bay! Not too proud to
that the vehicle wouldn’t move doesn’t necessarily entail that the battery had zero juice
could instead be software/engineering that means a remaining reserve is merely unavailable to the vehicle. From a usability perspective, that’s still consistent with “out means out”
I’m pretty sure that’s how Ford does it. If you drive till it’s dead, there’s still charge remaining to avoid battery damage.
lancersrock
Kody
USA - IA
Field Engineer
I charge to 90% every week day (well as close as i can get on my 24 amp charger). Once i have my 80 amp charger installed i may drop to 85% or even 80% during the summer. Right now im driving 145 miles in sub freezing temps most days, less than 80% and i most likely need to charge in route due to the lack of chargers the last 50 miles.
Simsonic
Sebastian
San Diego
2022 Lightning Lariat
Except no one is suggesting that you "continuously" plug in. Just once a day or so. It take about 5 sec to plug in and 5 sec to unplug. That means that you are saving less than an hour of time over the course of the year. Talk about "negligible".
I think this depends on your situation. I have a charger in my garage and I park outside. I also have to wrap my cord around my charger with some trash cans in the way. It's a bit more complicated than just plugging in. I'd rather spend the five minutes playing with my kids than worrying about plugging in everyday, when it's not that big of a difference for the battery longevity. The biggest issues are the ones we already noted - charging past 95%, below 10%, fast charging, and driving habits. Beyond that, 5 minutes everyday is 30 minutes for the week and quite frankly, my kids and my time are more valuable. I understand each person is different.
CAMB150
carl
NJ
F150-Lightning Pro
@PungoteagueDave
You are absolutely correct about F150L slow to get to 100%. My first time charging to 100%, the time to get to full charge kept increasing and never got to 100%. I finally pulled the plug at 98%. However I saw the app say 100% next morning, pretty weird. On my prime plug-in it always easily reaches 100% without issues.
MickeyAO
Mickey
San Antonio Tx
I don’t know how that would work engineering-wise. It’s kind of like a glass of water. You fill from the bottom, not from the middle. The reserve (empty area) is always at the top.
It's not like a glass of water where you fill in the bottom, and it is not cells being held in reserve (don't remember who said this) but is controlled based on voltage. Let's say that Vmax is 4.2 V and Vmin is 2.7 V at the cell level (NOTE: Yes we have data at the pack level but I have not drilled down to the cell level yet...too busy doing that with the Mach E data right now). The BMS would be programmed to use say 4.0V and 3.0 V (made up numbers, but voltage is not linear to SOC level) to keep from using the top and bottom of the SOC. Then, after they have enough real-world data, they can send an update that expands the voltage range.
Jim Lewis
San Antonio, TX
@PungoteagueDave
Most recently it took my ER 2 hours 45 minutes to go from 90% to 100% on a FCSP, the session started drawing at 17.891 kw, for 40 minutes, then stepped down to 13 kw for 15 minutes, approx every 10-15 minutes it dropped a tier the last tier was at 1.7 kw for 10 minutes, it finally tripped the 100% marker.
Coolbreeze704
Troutman NC
2024 F150 Flash - 2024 Tesla Model Y LR
Listen. Forget all these concerns and worries about SOC, what percentage, cold weather, etc, etc.
Just make sure you use a good synthetic oil and do your oil change EVERY 5000 MILES! Don't listen to this garbage about 10000 miles between changes. That is garbage. 3500 miles is a waste of money and valuable resources.
I have data to back all this!
Good luck
abel408
Schenectady, NY
2023 F-150 Lightning Pro
I figured Ford would have updated us with some kind of news on the situation today. :censored:
Same... One user on reddit reported that his truck that was sitting at the rail yard closest to his dealer for almost a month is now on the move back to the factory it seems :(. My truck was also sitting on the rail yard for a couple of weeks and has a similar build date as his. I'll be calling the dealership tomorrow to see if they can track it.
Status
