AntJohn73
- First Name
- Anthony
- May 16, 2024
- New Jersey
- 23 Lightning Lariat
Sorry, I have a Grizzl-E basic. All I can see is average over time on the Ford App.@Sealevel Thanks for the info. Does your L2 charger have a readout like mine does? I would like to see at what point the charge current drops. Thanks
That was from September so not cold by any means.@mr.Magoo Thank you. I knew something was wrong. What is your temperature where you live? It has been cold as hell here in New Jersey. It has been between 15 and 20 degrees here!
This (and I mean all the symptoms you described here) is very similar to what I am observing in the thread over here. If you get a Bluetooth OBD dongle, the free app (you pay to remove ads) Car Scanner can directly show your cell state of charge imbalance as well as the difference in average a minimum cell voltage.Thanks for all of the replies. Yes, it does reach 100% but it drops down right after the truck is "started". I believe they properly balanced the modules after #9 was installed. There are no codes at this point.
I wonder if the BMS software is incapable of balancing the modules when they are grossly out of balance. Some BMSes only top balance under certain conditions, and it’s possible those conditions are never met when the imbalance exceeds some threshold..But it's possible Ford has programmed the BMS to behave more cautiously when one module is substantially out of calibration to the rest of the original pack, cautiously slowing the charging rate should resolve once all modules are in alignment, 22 days was the stated time frame, yet the OP had work done in October, so at this point 60+ days have elapsed, why hasn't the battery reached a balanced condition by now?
I forget which member of the forum has a tracking spreadsheet for module replacement, my work was initiated in June and took about 7 weeks from diagnosis through replacement. I drove Blue Mule for 4+ weeks with the diminished charge level (67%) and the dealership worked on it for 2+ weeks. Mine was the first they had done and there were delays for missing instructions (including a special tool needed) and waiting for parts.How many of you guys have had modules replaced??? And how long did it take to get? Mine has been in the shop for a week with NO ETA for my replacement.
