sotek2345
Engineering Manager
That seller is really good. I got a button cover for my Lightning from them and helped them figure out the specs for a Mach-e one (it is a little different).
I asked them months ago when I bought mine about one for the Mach-E. They never responded.
Any idea when they will start producing them?
sotek2345
Engineering Manager
I would ask again. We got the dimensions figured out before the holidays.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
Does anyone know of good seat covers that also allows for good penetration for the seat heating and cooling?
BennyTheBeaver
Got my manual backup/generator inlet (compatible with the bed's 240v 30a Pro Power) installed and tested yesterday.
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 20230126_185036
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Interesting approach, moved 10 breakers to sub-panel, and added the selector switch. Do you know what model that selector switch is?
BennyTheBeaver
I unfortunately do not, I'm going to install my Emporia Vue within the week and will see what i can glean.
I'm not an electrician, I sent the electrician I use a description of what I wanted and forwarded him some links from the forum of what others had done (made sure he was aware of the neutral bond, etc) and this is what he put in. Everything tested out perfectly last night, and the price was much more palatable than the SunRun method.
georgepearkes
George
Charlotte, NC
F-150 Lightning Lariat ER
Very proud of the humble and dead-simple mod I threw in my Lightning today. Baby is due in January (our first) and will ride home from the hospital in style.
Turns out the workspace up front is a perfect changing table. Highly recommend.
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 13CD4412-F6EF-402C-968C-4A1E1F3F8558
boggle
CT
MY23 PRO
What is Tailgate Damper?
The non-powered tailgates on the lower trims don't have a soft open, just a lift assist. Ford makes a shock that attaches to directly to the hinge behind the right rear tail-light (FL3Z-99406A10-A). Going to see if it's compatible and can prevent the tailgate from slamming down. A few others here have mentioned wanting to try it, but haven't heard explicit confirmation of success yet. For $70 figured it was worth a shot. Will come back with the results.
Heres the stock hinge:
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 1674920109849
Here's what I'm hoping to substitute:
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 1674920146816
GarageMahal
JT
Data Wrangler
Had no idea there was a Ford part. I installed one from Amazon for around 20 bucks. Had to remove the tiedown/bottle opener from driver side of tailgate however.
