Propower Onboard Error Message
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
I took these three photos from the display in the truck. The back outlets are grayed out and can't be turned on or off. Another message suggests it is something that needs the dealer to fix. You folk are knowledgeable about these things and thought I'd ask here first what this all means.
Ford F-150 Lightning Propower Onboard Error Message tempImageSoEIOC
Ford F-150 Lightning Propower Onboard Error Message tempImageikLB3G
This is going to require dealer service tech to investigate.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
I've seen this several/many times before - no worries...
turn your truck OFF, then back ON, drive for a while... the message goes away.
it's more about the ProPower 'seeing' something it didn't really like, such as a spike, neutral or ground connection issue, etc... let these things work themselves out before you run to a dealer, they know less about this than you do, and it will likely take FOREVER for them to even diagnose it or give you any answer, and they may hold your truck as hostage until they figure it out... crazy.
these issues are similar to laptop 'issues'...sometimes the easy fix is to simply 'reset' the computer, turn it on/off. unplug it. let it rest, etc.
proprepper
Grayslake, Il
2022 Pro SR
done with work!
Vermin chewing thru the tasty wires. hopefully NOT!
My AT&T home internet just had to be repaired 1400ft from my house due to squirrels chewing the wires.
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
It's been there through quite a few on/off cycles. Earlier I've gotten messages that the pro power was within a few miles of something, but I don't recall what it said. Need to take pictures of these messages.
You may have the reserve range setting too high, lower that to 50 miles, see if it impacts the frequency of that message.
ctuan13
Chuck
Pittsburgh, PA
Have you tried a simple 12V reset? Disconnect the negative 12V battery terminal, wait ten minutes and reconnect. Start the truck and see how it behaves.
if you have the 'MILES' setting for ProPower too low, you will see this message, as it is the truck's way of alerting you to any draw on the battery that may could keep you from reaching your destination, or even if parked with ProPower on, not enough power to get to somewhere to charge... it's just an alert, until it reaches your set 'MILES', then it shuts ProPower completely off.
I set mine to 10 miles, as I will manage this myself and have hardly ever seen this message except when arriving home, with the camper being powered by ProPower, where I already know I will have power there.
I have, though, seen the 'Have your vehicle seen by your local dealer for servicing', or similar message, when the ProPower seems to have seen a power spike, or ground issue, or similar issue, but it always goes away on it's own, after some time, and some driving.
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
I have not. I will give it a go when I get a chance.
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
I looked last night, mine is set to 10 miles. Maybe I'll need to raise it.
I think you meant “too high”?
