ECG-25.2.5.7.1 - Consistent Battery (LVB) Performance
luebri
luebri
Neenah, WI
I simply want to modify the header to indicate that it's ~likely~ to be in EAP phase, not banning or deleting the conversation, I too have given up suppressing these types of threads, but would REALLY like to minimize the whining that's bound to happen.
BTW, another recent thread indicates the survey email server has suddenly come to life and folks are being flooded with stale communications.
SMH @Ford Motor Company
I belive our mentality is in lock step... any post should be 100% in the bounds of what we are allowed to share as EAP before we post. However if there are no specific guardrails, then I share, because that is why am on this forum... To both absorb and share information. If you believe you can read Fords tea leaves and this is EAP only then you can tag as you see fit. From my standpoint, I have seen very little ability to delineate.
P.S. I'm well aware of the onslaught of rogue EAP emails today, I got many! ?
I got my finger on the pulse, if folks chiming in would share their lack of or membership to EAP, it will help us all understand the context of what is happening, then as the process matures to general release, we will see that in time.
PJnc284
Garner, NC
Seems those who have reported it so far are 2022 EAP based on past posts.
Maineiac12
Iowa
Is this a Lariat only update? Curious why he called out the trim level in the tweet.
Blochead21
PA
Black 22 XLT 311pkg
Just got this update this morning on my 22XLT.
luebri
luebri
Neenah, WI
If anyone gets a notification that it’s installed in the app or in the truck, please say so. I found it very odd and not a good thing, but I did not receive a notification in either... our lives will be worse if we no longer even get a basic poke once we receive a haphazardly timed update.
Blochead21
PA
Black 22 XLT 311pkg
I also didn’t receive a notification in either. I decided to look this morning through the vehicle screen. It’s the only way I was told.
Elon's Wizz Kids need to visit Ford's IT operations, never mind auditing the US Treasury.
How can you find this info using Car Scanner? Do I have to install Forscan Lite? Cheers
To see the software version of any module in Car Scanner, click on ECU Identifiers.
Ford F-150 Lightning ECG-25.2.5.7.1 - Consistent Battery (LVB) Performance 1741357898373-b7
It will show a list of modules to interrogate. I usually go with the default list - but I think that excludes a few modules we really do have. It takes a while for the app to query them all and display the results. When finished, it displays the results. At the bottom of the screen is an Export button. I export the results to one of my cloud accounts with a date so I can compare.
You will see an ECU Software Number for each module. This corresponds to the Strategy number or the F188 value in FDRS that you see posted occasionally.
GWM
Assembly ver.: MU5T-14G650-GAG
ECU Software Number.: ML3T-14H021-RCP
ECU serial number: FUBCH2223503xxxx
VIN: 1FT6W1EV5NWGxxxxx
You can also use Forscan Viewer (free) or Forscan Lite (paid) apps. When you connect to a vehicle for the first time it interrogates the modules (can take a minute or two to fully connect). The module information will be under the Vehicle icon.
Ford F-150 Lightning ECG-25.2.5.7.1 - Consistent Battery (LVB) Performance 1741358461246-7f
CAUTION: it only interrogates the modules the first time and then caches the results. Subsequent connections will use the cache (connects almost instantly). To force a new interrogation, you need to click the Vehicle icon, click the gear (settings) icon on the lower right and choose Clear cache. Then Disconnect and Connect again. You will notice it takes a lot longer to connect since it is interrogating again.
Ford F-150 Lightning ECG-25.2.5.7.1 - Consistent Battery (LVB) Performance 1741358640861-zf
The results display more information than Car Scanner and I like when exporting it creates a file name with a date automatically.
The field you want is Strategy. It also includes a Calibration value that my be useful:
GWM - Gateway Module A
Bus: HSCAN
Part number: MU5T-14G650-GAG
Calibration level: MU5T-14G650-GAG
Strategy : ML3T-14H021-RCP
I also save these results using the Share icon (box with arrow) in the lower left on the Vehicle tab.
To use FORScan for Windows, after connecting look at the Modules tab. It has the same information as above. DO NOT CONNECT USING A PREVIOUS PROFILE. That will use the cache and it will not interrogate the modules. So clear your profile or connect using New Vehicle.
Mike G
N. AL, USA
Using Car Scanner / Forscan Lite, I was able to determine this OTA updated my Gateway Module Strategy (F188) from ML3T-14H021-RCL to ML3T-14H021-RCP
@Mike G @rugedraw
EDIT: It's now even reflected in my online As-Built.
Just saw this a few minutes ago. Did not show up when I took a drive this morning and hit the Software Updates menu item in Sync for some reason, even though it said the event triggered yesterday afternoon. I'll go out and see if I can get it to install now.
Ford F-150 Lightning ECG-25.2.5.7.1 - Consistent Battery (LVB) Performance ECG_25-2-5-7-1
Electric Messiah
Davis
Massachusetts
F150 Lightning Lariat ER
I got notified, both on screen and in the Ford App. The update was a bit of a surprise, occurring while truck was parked as I attended a meeting, and I noticed the on screen alert of this when I returned home.
Whammy Bar
1. Vehicle: 22 Lariat ER
2. EAP: Yes
3. How were you notified: No notification.
4. How did this update make you feel: Saw it in the ford*ass app when I checked to turn on climate that an update had applied. And then saw that the update interrupted my L2 charging at a Shell location. That I then couldn't restart. 5 out of 5 stars Ford yet again.
GWM
Bus: HSCAN
Very nice trick.
Received this when I went for a drive today. Had an immediate on screen notification and was checking the app, but it had frozen. When I restarted I do have an app notification, but no message has shown up just yet.
'22 Lariat - EAP for reference.
Just glad to see such a simple update can be produced after almost 3 years of ownership. They might just get this right before they are all in the junk yard.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Even that is hard to tell. I know I’m in EAP for FordPass since you have to use Test Flight to load it but I’ve never been told if I’m EAP for the truck software.
