K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
More likely the inverter (or inverters) are commanded off. The reason is that grid tied inverters are dependent on the utility power for a frequency reference (the inverters MUST sync to it), and more importantly, they always operate in max power mode - in other words, they generate as much AC power as they can based on how much DC is available from the solar. If there is no place for that power to go (since you can't export to the dead grid), the inverters shut off. They have no ability to regulate power delivery based on the local load.because here (Downeast Maine) if the power can't be fed back into the grid, it just goes (I guess) to ground.
