Charge to 100% on L2 charger, but GOM shows 84% on startup
bordner42
Brendan
F-150 Lightning Pro
Damn, I just noticed this issue happening to myself this week after noticing that the battery % was consistently showing 2-3% lower than the original estimate on it's first drive after being on the charger to and from work. Meaning that on the way there it was 2-3% less than estimated and at estimate on the way back. Paid attention to it today, and it showed being at 90% then dropping to 88% almost immediately. I've already had two battery modules fail, including one that just finished being repaired only three weeks ago, so it's pretty concerning that there could be a third bad already...
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
bordner42
Brendan
F-150 Lightning Pro
Joneii
Central PA
F-150 Lightning, Tesla MY
Definitely check your coolant level after this repair. I noticed my battery temp slightly elevated after a short fast charger session. The truck never had an issue with fast charging. I checked the coolant reservoir and it was bone dry. I added up to max. After a couple of days, I had to add some more. I think I caught it early, but this could have been detrimental.
With such a quick turn around they may have not vacuumed all of of the air out of the cooling system, so you might want to keep a close eye on the coolant reservoir. You can buy a gallon of the proper coolant and keep the reservoir at the middle in the reservoir if you see the level falling.
Similar, I needed a repair that involved dropping the pack. My coolant continued to go down over the next few days, eventually running dry. A quick top up and it hasn't gone down since.
frautumn
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
What brand/type of coolant are we supposed to use? I will need to check mine, wasn't aware this could be an issue after the module replacement. I did notice that the first time I charged after getting it back I was hearing some gurgling sounds from the battery area as coolant was circulating, and am worried there is air in there or not enough coolant. Will check when I get back to the truck.
EdRudy
Ed
Springfield, VA
Ford F-150 Lightning Charge to 100% on L2 charger, but GOM shows 84% on startup 1743700254998-43
GoodSam
Good
occupying space
I do not get why there are four variants for the Cooling System Capacities. Must be for those who have the Max Tow optioni?
Texas Dan
Daniel
On my first long trip (2,000+ miles) since replacing the bad module. The battery pack seems to be charging better than it ever did before. I have a feeling that the module had been going bad for a very long time.
Maxx
Slightly off topic: does anyone know a hack to setup home charging at 65%? I am not sure why Ford thought it is a good idea to do it right for one time charging but not here.
Nope, we noticed early on that the settings granularity was inconsistent below x value
F150ROD
U.S. Navy Retired
Well I started experiencing the same today, coincidentally after the Window Update. Charge to 90%, app shows 90% but the instrument cluster shows 89% smh
Close enough for government work, LOL.
I just got 25.12.0 this morning, I'll pay attention to this evenings recharge to 90% and see if it drops to 89% after unplugging.
F150ROD
U.S. Navy Retired
Just came back from a trip over the weekend and everything was great, holding charges at higher kWh longer and getting on the road sooner.
Edit: this morning back to normal. Odd, but happy. Will continue to monitor.
