astrand1
Alex
Studio truck driver
Why does it need to be 8-9ft long? Maybe I missed something but curious.
Ajzride
Alan
Houston
Eng
It's an electronics issue having to do with canbus signal reflections on an unterminated stub. You can read the whole techincal discussion here:
https://github.com/commaai/openpilot/issues/30302#issuecomment-2681736903
The summary is we need to add resistors close to the rearview mirror to kill off the reflections. Currently that is done by extending the harness and using only the short USB. But in theory you could use a long USB and a short USB (like they sent you) with some resistors in the coupler. That is what I'm going to try and make this week.
astrand1
Alex
Studio truck driver
Copy that. Thanks for the TLDR version. ? keep us updated. I’m definitely in on a group buy if it works.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Working perfectly. I'll let you take the PCB design on.
Ford F-150 Lightning Comma AI self driver assistant 20250505_161949
Ajzride
Alan
Houston
Eng
Well, this is exactly what I was going to try. I misunderstood what you had done.
I can skip prototype and go to PCB Design.
UncleTony
Tony
I originally mutilated a thunder bolt 3 cable and added resistors as needed. I went to a funeral over the weekend out of state and the boards were in by the time I made it back, just finished this today.
I shortened my jumpers so I can leave it installed and test it out. I was mostly stuck on the pcb design as I'm not an electrical engineer by any means.
Ford F-150 Lightning Comma AI self driver assistant 20250505_165452
Pod
2023 AMB Lightning XLT SR
So….reading the new posts was getting my hopes up. My XLT without adaptive cruise will not work with this, right. Bummed.
Ajzride
Alan
Houston
Eng
You can install radar DIY. It's been done by quite a few.
UncleTony
Tony
Just adding this in case anyone wants to get rid of the can bus errors and doesn't already have the custom harness. This is to be done at your own risk as I have only tested it for about 50 miles so far.
You just need these breakouts https://a.co/d/hFHdHoM as well as these resistors (as suggested by @Ajzride) https://a.co/d/h7GIwWR.
All you have to do is bridge B2 to B3 and A10 to A11 with the 62 ohm resistor on the breakout board. I would strongly suggest cutting the wire down as much as you can and solder the resistor into the wire. I would also not suggest you use this as a long term solution, but could save you from spending more or modifying your existing harness while the PCB gets worked out.
Everything you need outside of the resistors and what you need to solder is included in the kit.
Ford F-150 Lightning Comma AI self driver assistant 1746493542323-gb
Edit to add what mine looks like when complete now that I've had the time to solder it properly.
Ford F-150 Lightning Comma AI self driver assistant 20250505_212315
Ford F-150 Lightning Comma AI self driver assistant 20250505_212318
B177y
Oly Pen, WA
2024 Pro ER Max Tow
Why do you suggest not using this as a "long term solution"? It seems like it is functional, but maybe not the most visually appealing.
Ajzride
Alan
Houston
Eng
Too easy to bump a cable loose. I'm working on one today that is soldered and sealed for someone who can't wait for the PCBs to be developed.
For your application, you do not need 1/2 Watt resistors. You can go with 1/4W which will be smaller:
(6mm long instead of 9mm). https://a.co/d/a5wIarP
For your PCB solution, go with surface-mount SMD resistors. I have used jlcpcb.com to design many small PCBs. For a small fee, they install the resistors and the USB-C connector for you.
Ajzride
Alan
Houston
Eng
I’ll check JLB vs PCBway. I certainly was planning to have them install surface mount resistors and the USBC connectors.
Also, the CAN-BUS specification calls for 120-ohm termination at each end-point. I don't know your schematic - are these being connected in serial? 62 ohms I think would load the bus too much. Apologies if you're figured all this out (I see you're an engineer also). Feel free to tell me to mind my own business ;)
