Grumpy2
- Nov 23, 2022
- Central Oregon Coast
- 23 F150 Pro SR
- Occupation
- Retired Hvy Construction
It seems to me the battery module failures todate are due to two general quality control issues during original pouch fabrication or during module assembly, not on how the trucks are being charged and used. I am not sure a scanner will help on either QC issue.Before it went into the shop Car Scanner was showing 100% for the battery state of health. So I don't think it reliably tells you anything about the health of the HVB.
The current fire safety recall seems to be a module assembly quality control failure when they reference swelling and tabs shorting out. "We discovered that certain batteries were not built to the manufacturing specifications resulting in a misalignment of the electrodes ..." This sounds like a Ford QC issue. But if it is, why are we waiting on parts to solve this since modules do not seem to be in short supply now ??
There are modules being replaced regularly due to the other QC failure:
The subject of this forum issue centered on 2022-2023 models may be the result of a QC failure of spotting the pouch cells with lower voltage potential before inserting them into the module. I believe the only way of finding these poorer pouches is waiting for the BCM to send out the notice of a low energy pouch. To me this sounds like a SK and Ford shared issue.
I also believe the BCM protects the other modules when one or more have a failure condition.
It is so good that Ford used a repairable battery design. The structural battery design must have a system to drop out strings when cells go out of spec which would effect range without chance of repair.
