Powertrain Malfunction/ Reduced Power
ranger5ft21
Rick
2023 F150 Lightning Lariat ER
Was everyone’s repair covered under warranty? I had the same error and it was the diverter, not a module and it wasn’t even covered under the 5 year 60k mile powertrain warranty. It doesn’t make sense, but luckily I have an extended warranty and just had to pay for the deductible. But I would think it should be covered under the powertrain warranty since the error I was receiving was a powertrain error.
@Ford Motor Company Any reason it wouldn’t be covered under the Powertrain warranty or even the 100k battery since this is a specific EV part according to my dealership?
zakress
Zak
2022 Platinum Rapid Red
Chief Cook and Bottlewasher at Customer Experience Strategy
2 weeks ago got the BECM fault after a failing 12v diagnosis. Today got a 2 modules and neg HV junction box and it'll be 2 weeks for the parts. Def not in a regional parts center ATM
Gimme_my_MME
Incorrect, they are in regional parts centers
Bandit1982
North Carolina
Apprentice Trainer
My 23 Lightning battery module was covered under warranty. Only charged a couple of times at the house, but range is appearing now to be as it was before the problem.
zakress
Zak
Maybe they are supposed to be in Regional parts centers, but the Seattle one is out of stock for my modules. They have to come from the Midwest, so the plan or SOP is immaterial to customer need when it’s not within 1800 miles.
KennyB123
Ken
Detroit, MI
My turn. Pulled the codes on my ODB. This is what I see. What do you think? Bad 12v battery? 39.5k miles on a 2023 Lariat ER.
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power 20251107_222524
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power 20251107_222549
PrivateJoker
2023 Lariat ER, Telsa MY, 12 Leaf, 18 Leaf
Also got this on my 2023 Lariat ER on Monday. It's at the dealer, they're replacing the valve.
I also noticed heat wasn't working.
KennyB123
Ken
Detroit, MI
Just drove it 15 miles, heat was working and NO Powertrain message. 🤞🏼
republicoftexas1836
J
2023 AMB Lariat ER, 2025 Mazda CX70 PHEV
Noticed my truck had been driven yesterday (8ish miles via FordApp).
Just called, was told that the work has been completed, they are charging it up, I should get a call back in a few hours to pick it up.
Timeline:
Truck bought Aug 26
Truck becomes brick Sep 6
Truck towed to dealer Sep 8
Truck fixed and back Oct 1 (pending)
Days with truck working like truck: 13
Days truck is paperweight: 2
Days at dealer: 23
34% actual drivable ownership time with truck...not bad.
from the time of diagnosis to picking up a working truck, what was your timetable? I was just diagnosed with the battery module #4 failure yesterday and was wondering what time range I can expect to get back my truck. My update yesterday was that they are ordering the part but no time estimate.
T
2023 Ford Lighting Lariat
So from when I dropped it off to the dealer Sep 8th to getting it back on Oct 1st was less than a month. When they diagnosed the issue it was from Sept 9th to the 22nd.
They notified me of a battery module replacement ordered on the 22nd, so I would say from then, to getting my truck back, was a little over a week or so?
It just took them forever to get a specialist to do the diagnosis on it.
(Also should note, have had zero issues with my truck since and it is amazing.)
GoodSam
Good
occupying space
Could be as short as a week, or 6 weeks if Tech is backed up on other vehicles. One month seems typical. With your 20% limit on power, you can not drive it around until the parts get installed. Hope you can find a Ford rental so BEV customer service will cover beyond the $40/day rental limit ($60/day if on extended warranty?). Otherwise, they deny any extra cost beyond the very low daily limit.
Lui
lui
Toronto Canada
f150 lightning
Here is the Dealer joke... Wtf honestly
Got the wrench sign (service) with powertrain malfunction P0B24 code
Took it to the Weston Ford at Toronto
They said.. u need an update for the Battery module, 75 dollars for it. I said isn't that cover? because there was a CSP-23B57 recall about same issue. They said.. no!, Powertrain/Battery warranty doesn't cover it..
Called Ford Canada, they said they don't cover updates.. what a joke
Then I said ok 75 is ok I will pay for it..
Today I am going to pickup the truck and Weston ford said..
"Ups Mr,, the service representative you spoke with made a mistake. It is not 75 dollars is 645 for updates. Is that ok for u?" WTF Weston ford and ford service sucks
I will just take it to another dealer
Ford service is a complete 🤡🤡🤡
2022 F150 Lightning lariat
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_20251110_144702
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_20251110_143943
GoodSam
Good
occupying space
That code usually means a bad cell in one of the 9 HV battery modules. And you are limited in power (left gauge) to 57% which is usually another confirmation of a bad cell. Find a Ford dealer with good EV tech(s)...good luck. Your 8yr 100kmile (150k km?) warranty will cover. Call Ford BEV customer service. Arrange for Ford rental so that BEV will cover what dealer will not.
Lui
lui
Toronto Canada
f150 lightning
Thank you @GoodSam
module #7 problem for my 2022 lariat truck
1FT6W1EV3NWGxxxxx
Error P0B24 and 57% power
They told me they r waiting for parts 😞
What the percentage of fail after 1st fail?? Is it likely?
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power 78110-06a921409481e7e983162f396b0da9dd
