- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
I have a 2012 Leaf bought in 2011, 24kWh capacity now at around 85%.
On the Leaf forum, several people have been replacing the original battery with plug and play packs from Japan or China with 3 times the capacity (72kWh) for under $8k, this is one example post (from https://mynissanleaf.com/threads/su...0-26&utm_content=daily_newsletter#post-667358 ):
Battery Retrofit: Specs and Cost
Personally I would wait for newer battery tech (solid state) to be integrated into an upgrade before I'd bite.
There are also battery swap companies proliferating in China, and some fleet operations in Ca. doing that as well, so down the road that might be an option.
Absent another pandemic, the battery tech improvements will continue full speed and the prices will keep dropping, so I am optimistic that when needed, there will be options for replacing the Lightning battery.
I'd want a decent length warranty if I replaced the battery, too.
- Modules
Eight 7.2 KWH VW/AUG Etron NMC Lithium modules were purchased as a plug and play. Each module weighs approximately 66 lbs (30 kg), with the total pack coming in around 530–550 lbs (240–250 kg). The original 24 kWh Leaf battery weighed about 485 lbs (220 kg), so the upgrade adds only 50–65 lbs. - Safety and Thermal Performance
Modules are designed for a 580 A discharge rate (per VW motor controller nameplate), the system seems to have excellent thermal characteristics during both charge and discharge. - Supplier Information
modules were purchased from EVClassix specializes in Leaf battery upgrades and EV conversions for classic vehicles.
Website: www.evclassix.com
Email: [email protected] - Price
Battery pack to (including CAN Bridge, tariffs, and taxes): $5,420
Door-to-door shipping to Portland Oregon from China: approximately $1,400 (delivery in 50–60 days)
Total delivered cost: $6,820 - Installation
Installation performed by EV Rides in Portland OR for $700. This includes testing the battery, sealing the modified case, installing the undercarriage shroud, and wiring the CANBridge filter.
