galstaf
North Georgia
2015 LEAF x 2, 2022 F150 Lightning Lariat ER (511A trim)
community offgrid training
Ok went out this morning and the c4 worked for a little while then have the "calibration invalid". Rebooted the truck and c4. Still doing it. Tried recalibration 3 times and still failed with the same error.
Has anyone seen this on the c4?
Any ideas?
Ajzride
Alan
Houston
Eng
Any ideas?
that is a new one.
upload the route so I can take a peek:
chriserx
Louisiana
Any ideas?
On the C3 one of 2 things happened here:
1) Mount is loose
2) Comma is not centered and leveled properly, its just good enough to not immediately throw an error, but just bad enough it eventually sees a problem.
While you are looking at a C4 specifically, I suspect it's still one of these issues.
Reactions: EVO
B177y
Olympic Peninsula, WA
@galstaf
For models, I have settled on using North Dakota (Legacy > North Dakota). It's all the goodness of WD40 but it doesn't hug the right side like WD40 did. YMMV, but it's worth a try while you're trying out different models.
Ajzride
Alan
Houston
Eng
I make all of my prototypes from PLA because it is cheap and easy compared to automotive grade filaments. I left ths one up this morning when I tested it. 3.75 hours later and it is only 81F today.
Ford F-150 Lightning Comma AI self driver assistant IMG_5033
KingStraasha
Kevin
Dayton, OH
2023 F-150 Lightning Lariat ER, Antimatter Blue
I have a C4 on my 2023 lightning Lariat and here are the settings that work best for me.
- North Nevada V2. All the settings below are related to this model. I assume other models will require different settings
- Lane Change Factor: 0.75 - feels natural
- Use Custom Tuning Profile: Enabled
- Predicted Curvature Blend Ratio Low: 0.4
- Predicted Curvature Blend Ratio High: 0.4
-- The Low and High settings felt steady with no ping pong and only small amounts of drift.
- Enable Advanced Lane Positioning: Disabled. When I enabled this, it would cross both the left and right lines during turns and hug the left lane while driving straight. When disabled, my truck stayed roughly in the middle the entire time.
- Enable Legacy Style Lanefull Mode: Disabled
- Custom in lane positioning: 0.0
- Low Curvature PID Gain: Does not apply when disabling Advanced Lane Positioning. I experimented with everything between 3 and 5 and nothing fix crossing the lines and hugging the lanes to my satisfaction.
steelersmb
Marc
Atlanta
Ford Lightning Lariat
I just received my Comma 4, and I have a 2023 Lightning. I'm planning on attempting the installation this week. This is a pretty long thread, so I wanted to ask what the best video or guide is to follow for the installation?
Ajzride
Alan
Houston
Eng
Lake Placid Lightning
2023 Lariat SR w/510A
Civil Engineer
What was the length of time between the date you placed your order and when you received it?
