branden
consider me interested if this is to have Comma and FitCamHere is the production version;
Yep, just send me a DM with your address and I'll get one shipped Monday.consider me interested if this is to have Comma and FitCam
Do you have the lightning coupler?I just received my Comma 4, and I have a 2023 Lightning. I'm planning on attempting the installation this week. This is a pretty long thread, so I wanted to ask what the best video or guide is to follow for the installation?
Yes I do. Thanks.
If you have one of our docks, that video is here:Yes I do. Thanks.
What was the length of time between the date you placed your order and when you received it?I just received my Comma 4, and I have a 2023 Lightning. I'm planning on attempting the installation this week.
Hey.. sorry.. been out of town but still having issues. I did get the device to reset via SSH with a Bash script chatgpt helped me make. It wipes out the existing calibration and gets the device ready to accept a brand new calibration.that is a new one.
upload the route so I can take a peek:
Take pictures of all your settings in sunnylink and send them to me in a DM. This is a weird issue for sure, and could even be a bad tilt sensor in the device. I can help you work through it in DM, no reason to tie up the thread.Hey.. sorry.. been out of town but still having issues. I did get the device to reset via SSH with a Bash script chatgpt helped me make. It wipes out the existing calibration and gets the device ready to accept a brand new calibration.
cd /data/openpilot || exit 1
test -x ./launch_openpilot.sh || { ls -la; exit 2; }
pkill -f "launch_openpilot\.sh" 2>/dev/null
pkill -f "manager|modeld|controlsd|locationd|boardd|pandad|loggerd|logmessaged|camerad|sensord" 2>/dev/null
sleep 3
rm -f /data/params/d/LiveCalibration /data/params/d/CalibrationParams /data/params/d/IsOnroad 2>/dev/null
sync
nohup ./launch_openpilot.sh >/tmp/op_launch.out 2>&1 &
sleep 15
ps -ef | grep -E "launch_openpilot|manager|modeld|controlsd|locationd" | grep -v grep
cat /data/params/d/IsOnroad 2>/dev/null
ls -lh /data/params/d/CalibrationParams /data/params/d/LiveCalibration 2>/dev/null
tail -n 80 /tmp/op_launch.out
ps -ef | grep -E "python3 ./manager.py|modeld|controlsd|locationd|camerad|sensord" | grep -v grep
cat /data/params/d/LiveCalibration 2>/dev/null
sleep 20
This put the C4 back into reset calibration mode and it worked fine for the rest of the day. However powering the truck off overnight and it was back in "Calibration Invalid" again.
I will try what you suggested and upload the logs for you.
Again, I have it on the factory mount just below the mirror and didn't move the device from one session to another. Also, the device seems to still be seeing other vehicles in the greyed out background, so it is doing stuff but just not actually doing it's job.
Would using another model help do you think?
Hi Alan.. thanks for the quick response! I will ask the following publicly in case it helps someone else. But I can send you any data you want privately.Take pictures of all your settings in sunnylink and send them to me in a DM. This is a weird issue for sure, and could even be a bad tilt sensor in the device. I can help you work through it in DM, no reason to tie up the thread.
The LTE hotspot is off when the truck is off.Does Sunny Pilot not permit uploading via the LTE modem?
just take the device inside and power it with a phone charger overnight to upload logsHi Alan.. thanks for the quick response! I will ask the following publicly in case it helps someone else. But I can send you any data you want privately.
Re: This issue with BP4
Should we even bother now that BP6 is released? Should I just use this instead? How stable is the beta?
If you do want the logs, question:
I am not near the truck right now and there is no wifi. I can connect to it via Comma Prime, but it is saying all the uploads are paused waiting on wifi. Does Sunny Pilot not permit uploading via the LTE modem? If that is not the default behaviour, is there a way to make it so? I don't have wifi access in our parking deck at home.
It was about 6-7 weeks I believe.What was the length of time between the date you placed your order and when you received it?
I'm a bit confused about the coupler. The video says that if you are using a quick-release dock, you don't need to use the coupler. Where does the coupler connect to? I'm assuming you plug the coupler with the lightning end into the black piece with the USB C connector and then the long USB C cable into the Comma end of the coupler and then into the Comma 4.
We did sell some docks with an integrated coupler, but we ran out of those. Most everyone has an external coupler.I'm a bit confused about the coupler. The video says that if you are using a quick-release dock, you don't need to use the coupler. Where does the coupler connect to? I'm assuming you plug the coupler with the lightning end into the black piece with the USB C connector and then the long USB C cable into the Comma end of the coupler and then into the Comma 4.
