FCSP Software Version 2.500.34-ford.27+26-08
abcut973
Anthony
Denham Springs
2022 F150 Lightning Platinum, 2020 BMW X7 xDrive40i, 2019 Mercedes C300 cab
To be clear, I don't know 100% if this is a separate issue, or one that's caused BY this.
What I do know is that my unit stopped working over the weekend while the OTAs were rolling out, and my logs show that it had multiple 'failed' downloads.
I'm running 2.112.125:0.0:0.0:0.0 on the outside unit that stopped over the weekend.
The inside unit I repaired today is now running 2.12.125:3:15:3:15:3.15
Those are both BEFORE the problematic OTAs, so maybe my issue saved me?
Ok.
Mine is already at 3.15 since last year OTA.
Aminorjourney
Nikki
Internet
www.transportevolved.com
Ok.
Hmm.
I'm currently imaging the disk so I can work on it remotely from the unit - but I will also leave my bench system attached with the hope it actually *does* do the OTA update.
I wonder if the recent OTA to the FCSP has been suspended?
Jim Lewis
San Antonio, TX
Given how consistent it is, I strongly suspect this is the root cause behind a large share of the "unit stopped responding" reports in this thread over the last few years — not a WiFi bug, not an app bug, a disk-full bug wearing a dozen different disguises depending on what happens to try writing at the wrong moment.
Great discoveries by you and @cjueden. I think it's good you qualified your estimation as "a large share of 'the unit stopped responding' reports," as other snafus with the FCSP may exhibit similar symptoms. Around April 2024, I lost both Wi-Fi connectivity and BT broadcasting from my FCSP. A hardware FCSP reset restored Wi-Fi; a software FCSP factory reset through the FordPass app restored FCSP BT broadcasting, but I couldn't repair the FCSP with my truck until I factory reset my truck! https://www.f150lightningforum.com/...y-for-truck-fcsp-bad-behavior-problems.19650/
As reported in this thread, on 8/7/26, I seem to have gotten an earlier FCSP firmware update version than anyone else (5.2.2 rather than 5.3.6). I lost charge derating but not Wi-Fi connectivity. The same situation continued on 8/8 when I got firmware update 5.3.8, slightly newer than the standard issue 5.3.6. But just this Tuesday, 8/11, still on 5.3.8, I got a Connection Lost notice and couldn't connect to my FCSP either through the Ford app or the Ford CSP Pro Setup app, even though the FCSP SSID was showing in my iPhone Wi-Fi settings. So I turned off all power to my FCPS, including the HIS unit and its Dark Start battery, and let the FCSP sit for 74 minutes. Within 2 min after rebooting, the FCSP broadcast its SSID. I could connect to it via the CSP Pro Setup app (the Ford app initially gave Connection Lost). But a minute or two later, I could derate the charging current to 24A, change the charging time window, and see that the FCSP was charging at 5 kW as requested. When I tried the Ford app 40 min after the reboot, it connected to the FCSP and had it reporting "Ready to Charge."
So, the state of my FCSP might be something interesting to investigate via your techniques, @Aminorjourney, but right now, I'm just happy to have it working, and hope that your and cjueden's findings encourage Ford to do some heavy lifting and clean up their mess, and save us all a bunch of future frustration and time wasted messing around with our FCSPs.
Aminorjourney
Nikki
Internet
Thanks for the encouragement, and good to know it's not everyone.
I've forwarded my bug report to Ford, and I've made a copy of the disk image, so I can at least work with it offline. Watch this space!
I tried upping my charge rate to 60A. It says it saved in the app but it does not appear to have taken. I'm still charging at 40A. I'll try adjusting again after I get a chance to reboot. Perhaps it's a one and done per boot.
cjueden
23 ER XLT
The app doesn't verify the settings took. It sends the command to Ford's OCPP server but doesn't make it to the charger sometimes. You can try again by going one up or down in the app and hope it catches. So long as it's not the max rated amp or 37% of it. There's a bug in the firmware for those settings.
I might have done a reboot, or just hit the lottery on the request posting.
{didn't hit the PowerBall big time last night but did walk away with $8}
tearitupsports
Russell
Cypress, TX
It is interesting to me that the one piece of equipment that has been rock solid for me has been the FCSP. I have never had connectivity issues or problems like everyone else.
The two possible reasons are that I have always had it dialed down to 64A or below using the hardware limit.
I also have it networked such that it always receives the same IP address from the router. That address is also in a different part of the subnet which is not used for the random DHCP addresses. I am wondering if a changing IP address is what is causing the stations not to work, or then suddenly start working correctly again. I also have no chance of duplicate IP's in my scenario.
I have noticed forever that if I set a lower charge rate in the app it would work immediately. If I tried to raise it back up, it would never work until power cycling the station. The new setting would be active immediately after the power cycle.
That's an interesting observation. I'll experiment a little tonight before I reboot.
Using 80 amps as my default has been fine, and I also reserved the IP on my network for my FCSP, well until recently experimenting with this recent problem.
Otherwise my unit has be very reliable.
K6CCC
Glendora, Calif.
All of my known devices have DHCP reservations in my route so my FCSP is always 192.168.206.192. My 206 LAN is all IoT type devices (mostly cameras and power control devices).
Jim Lewis
San Antonio, TX
Relative to the success of getting FCSP connectivity and charge derating back after a cold reboot yesterday, my Ford app is now again saying "Connection Lost," but I can still connect to my FCSP with the Ford Charge Station Pro Setup app, and last night during 2 short tests and during a 2 am to 3:27 am scheduled charging session, I was able to charge at a derated 5 kW, as set. Given how finicky FCSP behavior is these days, I'm just going to leave things as is and not push my luck by checking whether I can still change the derated charge amount. I'm leaving my truck unplugged in hopes of getting an improved (repaired?) FCSP firmware update from Ford.
K6CCC
Glendora, Calif.
A change today. I charged last night from 2131 to 0539 this morning. The Ford app showed the power prior to disconnect, and after disconnect the session showed correctly in the Charge History. However when in the Ford app and selecting the Charge Station and then Insights, the session did not show. Prior sessions are still there. Prior to today, charge sessions did show on Insights.
As expected, if I try to connect to the FCSP via the Charge Station app, it is listed, but can not connect - no change.
Ford F-150 Lightning FCSP Software Version 2.500.34-ford.27+26-08 Charge History 2026-08-13
Your FCSP is in the same operating condition as mine with the corrupted firmware update.
The statistics we can see are coming via the truck telematic data, while the insights data from the FCSP itself have gone silent because of the mishandled log files being generated at the moment.
I'm done trying to experiment with my unit until we receive word on how to remedy the situation.
Luckily, I have my Emporia energy monitor for actual gross energy consumption, which frequently matched the FCSP values to the tune of 99% match, so it's not a big loss to me, but the integrated statistics inside of Ford App for long term analysis was nice .... while it lasted!
