Curious why some do not use 1 pedal driving.
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
There was a report from china where 1pd caused a lot of low speed accidents because people could not stop fast enough by lifting their feet of the speed pedal. And new drivers didn't have the muscle memory of pressing the brake pedal when in doubt.
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
Hot take…
I feel it was always a compromise born in the infancy of EV’s to cope with the inability to smoothly blend regen with friction brakes.
Ford, and others, have solved that problem, IMO.
Not that you can’t prefer regardless.
Heliian
Yes, when driving in snow and ice you want to be able to let the wheels turn freely at times.
Hence in the olden days of automatic transmissions you would shift to neutral to have better control while trying to stop on ice.
It's very difficult to threshold brake with 1pd.
davehu
hot springs, AR
Keeping in mind that I do not have a Lightning yet, so have never had the opportunity to drive a vehicle with 1 pedal mode. However once I do, I will drive multiple vehicles that are all 2 pedal vehicles. In an emergency I don't want to have to think which vehicle I'm in and how to panic stop.
It won't matter if your 1p or 2p, if you need to make a panic stop SLAM ON THE BRAKES! I use my wife's car occasionally and it drives me nuts. You take your foot off the accelerator and the car keeps going, and going, and going. NUTS to that, give me 1PM!
K6CCC
Glendora, Calif.
1, 2 or 3 pedals shouldn't be the problem, driver training is the issue.
In my opinion, the issue with 1PD is that it is different than every other car we've ever driven and any other car we might drive (borrowed car, rental, other family member's car, etc). If every car used 1P mode, it would be fine - but the vast majority of cars don't. I don't want to have drive different every time I change vehicles.
Also in my opinion, Ford has done a fantastic job of making the Lightning drive exactly like any other car with an automatic transmission. I could hand someone a fob for my truck and not even have to tell them that it's electric and they could drive it just fine. Well other than the first time they punched it and damn near ended up in the back seat :)
Highpi
Ken
Sacramento, Ca.
2025 Lightning Lariat, Iconic Silver
Before I bought the truck, I thought I'd never use it. During test drives, it seemed a little jerky, but after using it for a bit, it's just become automatic.
Of course, when I drive my wife's hybrid, I keep wondering why it isn't slowing down when I take my foot off!
25StarWhiteLightning
Midwest
2025 Star White Lightning Lariat
How is it people same it's the same regen. If I am using 1P the brake coach says 100% but if I use my brake pedal at all it comes down below 100%, but still in the 90s. Can't see how using brake pedal is the same efficiency. Once you get used to it, I can't see going back. Snow is coming, so will get to experience it there as well.
K6CCC
Glendora, Calif.
One of the fields that can be watched with CarScanner is brake system pressure. Regen braking does not cause brake system pressure to go up. Only friction braking does. Having watched it, I can assure you that unless you hit the brake pedal fairly hard, that pressure does NOT go up until you get down to a quite low speed. Therefore, I am positive that 2 pedal mode DOES use regen braking just as 1 pedal mode does.
Midwest
Not saying it doesn't use regen, but it doesn't ONLY use regen, so can't be as efficient as 1P drive.
Jim Lewis
San Antonio, TX
The basic reason I don't use 1PD is that its braking is too sensitive to the amount of reduced pressure on the accelerator. Using the brake pedal, you get much more incremental control in braking, plus the ability to better incrementally creep forward in 2PD by just lifting your foot off the brake pedal. You don't get the same easy, broader range of adjustment in braking and creeping with 1PD, IMHO.
Jim Lewis
San Antonio, TX
All this bit about 1PD giving you more regen.... I bet most of youse guys blow that regen out the window when you floor it to get onto the freeway, etc., .... 😁
chriserx
Louisiana
I tend to think that maybe it's an outside factor like current temperature, but out of curiosity has anyone encountered their efficiency at interstate speeds go up when using 2 pedal? The last several drives I've had GOM says its a not insignificant .2 to .4 mi/kwh higher after the change back. The only thing I can see is that on approaching another vehicle is coasting towards it instead of braking saves the overhead of putting the energy back. For the record the interstate drive is solely handled by a comma running bluepilot.
Jim Lewis
San Antonio, TX
This is a "feature" being discussed around the web right now. It's a comfort thing that is unnecessary.
If you have just inches to spare in your garage to fit the truck in, it's A FEATURE and not a comfort...
