MountainAlive
- Apr 18, 2024
- Massachusetts, USA
- 2023 F-150 Lighting Lariat ER 512A Max Tow
In other words, the discussion by others that the OP might have known there was a problem with his Ohmmu battery well beforehand, but kept using it, might be an excuse for the companies involved to deny culpability and shift blame and responsibility to the OP.It's likely the member deleted his/her account due to the sensitivity of what has happened and possible claims of fault flying about.
As a lawyer I would have done the same thing. When I read that he had the Ohmmu battery I thought to myself that maybe it's not a good idea to post about the situation publicly. There's a nonzero chance insurance will deny the claim due to the owner making an unapproved and unsafe (in their opinion) modification to the vehicle. There's evidence here of one of those batteries catching fire. If there's evidence that OP was aware of that (say, if he commented on that post) it would really hurt his case. It's best OP lays low and keeps his mouth shut.I've received word from a trusted source that the truck fire was a real event.
Just to be fair, the one that caught fire was their Lithium ( LiFePO4 ) version and I do have a vague recollection that OP had the Sodium (Sodium NA+) version. So yes, same manufacturer, but not the same type of battery / chemistry. Maybe someone have better memory than me and can confirm or correct ?There's evidence here of one of those batteries catching fire.
We don't know if the battery was the cause of this fire. But I strongly recommend that people stay away from the Ohmmu battery.
Lies, Damned Lies and StatisticsI feel a lot better about my Electric Horse after reading these statistics.
Numbers don't always tell the full story. There is a good chance out of a 100,000 EVs a higher percentage is newer since each year more is sold than last. 100,000 ICE vehicle in this stats are more likely have a higher mix of older ICE. If the age of the vehicle increases the fire risk, these numbers can be misleading. If they have corrected for the age and compare only cars less than 3 years old for example, the numbers would be a little more trustworthy.Here's some data I pulled off the web regarding percentage of fires per type of vehicle. EVs get more coverage in the news because the fires are harder to put out.
Vehicle TypeFires per 100,000 SoldEstimated Fire Percentage
Electric (BEV)~250 Vehicles or .025%
Internal Combustion (ICE)~1,530 Vehicles or 1.53%
Hybrid (PHEV/HEV)~3,475 Vehicles or 3.48%
The only reason I posted that is that @mr.Magoo said fires happen to those that worry the most so I thought if I can make everyone else worry more, I can reduce the chance of my truck catching on fireApoligies to Maxx, i certainly didn't mean your post. The stats could be normalized for age at the least.
From the Transportation Safety Board (NTSB) and international studies (2024–2026)Numbers don't always tell the full story. There is a good chance out of a 100,000 EVs a higher percentage is newer since each year more is sold than last. 100,000 ICE vehicle in this stats are more likely have a higher mix of older ICE. If the age of the vehicle increases the fire risk, these numbers can be misleading. If they have corrected for the age and compare only cars less than 3 years old for example, the numbers would be a little more trustworthy.
