Pre-conditioning.
Robert1380
Robert1380
Robert
Retired law enforcement
If you are on the road travelling, this is what happens:
Yes, the Ford Lightning will pre-condition its battery when a DC fast charger is set as a destination or waypoint in Google Maps on Android Auto. This feature, known as En-Route Preconditioning, ensures the battery is at its optimal temperature for fast charging when you arrive.
Here's how it works:
  • Using Google Maps:
    When you set a DC fast charger as a destination or waypoint in Google Maps (projected onto your in-vehicle display through Android Auto), the vehicle's system will automatically begin to cool or warm the battery as you approach the charger.
  • Timing:
    The preconditioning starts a certain distance from the charger, allowing the battery to reach the optimal temperature before charging begins.
  • No need to manually start:
    You don't need to manually trigger preconditioning; the system will automatically do it based on your navigation.
  • Benefits:
    This ensures that you can achieve the fastest possible charging speeds at the DC fast charger.
Really great information. When I took delivery of my truck a little over a week ago, they paired my phone and showed me where to plug it in for charging. That was it. No explanation of any of the systems or how they work. Was a fiasco. Thanks for your help and I appreciate you.
Firn
23 Pro ER
  • Timing:
  • Benefits:
Have you verified this is true for the Lightning? What yesr and Software version?
It has been said that the latest updates may have included this feature but it was confirmed that prior to that the Lightning did not actively precondition the battery for DCFC, and that has been validated by a few (myself included).
There was discussion that perhaps 10.2 did add this feature but there have been no confirmation that this is functional on the Lightning as of yet.
earlyadopt
Woodstock
MachE, Lightning XLT
Insurance Broker
You are welcome, I have two EV's and done lots of research on them. Google is also amazing. The challenge sometime on these forums is a bit of opinion comes into the mix and can cause confusion. I was watching the thread and the answers are not wrong, just that if charging at home, the pre-conditioning works to preserve your battery. En-route pre-conditioning is done to optimize the charge experience and reduce time at the DC charger. Two totally different objectives. Enjoy the truck, they are awesome and cheap to operate. No stock car can beat you off the start line. This truck is "lightning fast" LOL
potato
BC, Canada
2023 F150 Lightning XLT ER
The word "precondition" is used for both the cabin and the battery, although they are completely separate things. I think that's the biggest confusion. I wish there was a better word used for preparing the cabin.
RailroaderJ
Julian
2023 F150 Lightning Antimatter Blue
I'm curious if it cools the cabin\battery while plugged in at 240V
Yes, it does both, as observed in winter by my Emporia energy monitor.
Red1hour
2025 Lightning
aviation
Do we know for sure that the 2025 Lightning will optimize battery temps when plugged in to 240 (Level 2)? really curious about this one as Mine will be outside all the time.
I don't own a 2025, but I'm sure others have confirmed that it will warm the HVB when conditions are right, plugged in, ideally to 240v EVSE, departure timed event is set, the system will bring the HVB up to minimum operating temp's, if the heat pump can't handle the task, the PTC will kick in to boost the temperature.
EDIT:
It will also do spontaneous warming to the bare minimum in extreme cold even without a departure time, tested this a couple of time on my 2022.
Ford's Important Tip For Driving Your Lightning in the Cold: Preconditioning / Pre-Heat Your Battery
Tips to Maximize Your F-150 Lightning Electric Range (Preconditioning, Hauling/Towing, Driving Tools)
ClevelandBeemer
2025 F150 Lightning Flash 131kWh
2025 Job 1 Flash owner. Can confirm it preconditions as well as keeps the pack above freezing on Level 2.
doggod
Jef
Mendocino County, California
cybertruck, f150 lightning, model S Plaid
my observation is the battery temp gauge never moves it is always in the middle. my temps are from 40-110 winter to summer. once in a while we get below 40 and see some snow but it will melt within a day or two. most of the year we are 50-70. Ukiah where we shop and it gets hot there summer is 90-110.
