MillieChliette
How can you already own an EV yet simultaneously seem to know so little about how range is calculated? It's a guess. It guessed wrong.
Your truck worked exactly as expected with ~1.6mpk in freezing temperatures on the highway with climate at a comfortable level (and also likely a headwind since your return efficiency seemed better). I know it seems to not have been your fault that preconditioning didn't work when you left your house, but remote start does not condition the battery. It will still help since it will use shore power getting the cabin to your desired temperature instead of battery power once you depart. Then using remote start again before you left to go back home was just wasting battery. Why would you do that if you were so anxious about the range?
Literally any EV available today would have shared similar range loss for your trip including your Mach e.
