✅ 11/14 Lightning Build Week Group (MY2023)
EdwinT
NJ
Wsl346
Austin, Texas
5 left.
WesleyFL11/14/202211/17/202211/16/202212/15/20221/6/20231/4/2023LariatER
balucipherFL11/14/202211/17/202211/17/202212/9/202212/31/2022LariatER
Yabra2WA11/14/202211/18/202211/18/202212/9/202212/16/20221/7/2022LariatER
tlinKS11/14/202211/19/202211/20/202212/15/2022LariatER
Yanni CakeGA11/14/202211/20/202211/20/202212/9/202212/27/2022LariatER
Wesley
Wesley
Gainesville Florida
Ford raptor
5 left.
New ETA 1/22-1/28
drdirk
Houston
F150 Lightning Lariat
I’m confused by this lol
Well, it's not a joke, if you look in your front trunk there is a reservoir for coolant. Keeps the battery and electric motor cooled. Heat is the enemy of batteries. Don't neglect that.
laselvasurf
Phil
Santa Cruz CA
I have a 1000 miles on my xlt SR and just checked it for the first time while removing the front beeper. The fluid was still right in the middle, no loss at all.
EdwinT
NJ
I get that but I thought the coolants had a very infrequent change cycle? And nothing should be consuming them right?
Are you going to drive around with it just incase ?
Monkey
Somewhere in the mountains
Coolant should very infrequently need to be checked and topped off. Similar to coolant in an ICE vehicle... It's really only a problem if there's a leak. Another forum member started a thread about this and that he's noticing low coolant level, which probably means he has a leak somewhere. I think it's made a few members here paranoid. Yes, sure, check the levels and all that, but unless you're pushing the vehicle extra hard in both driving and charging or you have a leak, that coolant shouldn't need a top off more than every 10~15K miles or more.
tlin
Wichita KS
2023 F150 Lightning Lariat ER; 2022 Wrangler 4xe
5 left.
New ETA 1/28 to 2/3. Still not in shipped status yet
drdirk
Houston
I am not planning to keep it in the truck, but I guess I have a OCD personality so whenever I buy something I try to get the most common "spare parts" stocked in case I need it. I dont expect to loose any, hopefully, but if I do and have a trip planned it will be in the garage with the spare parts for my house.
Day 4 and I love the truck. Best vehicle I have ever owned. The only minor complaints I have is lack of dog mode and too many dings and beeps so will try to disable some of them.
Yanni Cake
Kyle
Scottdale, GA
Subaru Crosstrek
5 left.
Shipped on 1/7/23. Estimated delivery is still 1/21-1/28.
Did u contact Ford customer service about status? They could tell u the last rail check point and rail car number..
Last time I contacted them they mentioned my truck now is eta 1/20 at dealer
Truck arrived
Yabra2
Sammamish, WA
Took delivery on the truck yesterday.. Azure gray metallic looks way better in person ?
Unfortunately I have the same issue as many others with modem and activation which customer service said they have a fix ETA early Feb.
Dolio
Ryan
Tacoma Region, Washington
youtu.be
2023 Lightning Lariat ER Max Tow Carbonized Gray
Try unplugging the 12v for ~10minutes (probably less)... I had trouble activating and tried all available resets and reinstalls in both truck and on the phone. After plugging back in the 12v battery and waiting for it to cold boot up was able to activate the truck with the Ford Pass app without any issue. BTW: Just pull the frunk closed by hand after restoring the 12v. ;)
Yabra2
Sammamish, WA
Today it worked .. probably got the modem update via WiFi.. so am able to activate it now but my bluecruise map still out of date.. Will wait for more updates I guess.
