Priority Update: 22-PU0930-RBA-CHM: Frunk Chime Vol, SOC digits
chillaban
2022 F-150 Lightning Lariat
Full release notes because Ford doesn’t publish them-
Summary
Priority Update 22-PU0930-RBA-CHM for 2022 F-150 Lightning vehicles is now available. Quality Improvements include: - Updated Frunk Chime Strategy - Removal of brake assist warning pop-up - Mitigate erroneous Crosstrafic Assist pop-up due to incorrect configuration - "Emergency Tow Enabled" is now correctly called out instead of "Neutral Tow Enabled" in the popup. - Improved key off load (KOL) - Enables Low tire pressure warning to show up on Ford Pass.
Can Ford just give us THESE release notes instead of the creative writer writing 2 pages of cringe yet still not mentioning important behavior changes?
Whammy Bar
This break anyone else's standard chimes? The do-dooo-doo standard chime now cuts off mid do-doo....... And never plays the third doo.
Hallelujah. It took a year, but we finally got the battery percentage added to the main screen.
It's a good thing the software developers don't work for NASA. We'd never make it back to the moon in my lifetime.
ChrisCon
The Hamptons, NY
how do you see these updates??
There isn't an easy way that I know of. With certain updates that are considered "priority updates", Ford issues a TSB so you just google the update name with the letters TSB or search through all of the TSBs manually and look for the corresponding update which is what I did with this one.
Also after 7 failed attempts yesterday, I woke up this morning after my truck preconditioned and it installed without issues on the first try.. There seems to be absolutely no reason why updates fail unless preconditioning charged my 12V battery?
Mike G
N. AL, USA
Anytime you do a remote start the DCDC charges your LVB.
Willebrew
Will
Dallas Texas & Denver Colorado
Rivian R1T Pre-Order | Lightning Lariat ER Owner
Software Developer & CEO - ADAS research and development for fun
I received this update last night, has anyone else noticed that the BlueCruise hands-on wheel logo is now white instead of blue?
Ford F-150 Lightning Priority Update: 22-PU0930-RBA-CHM: Frunk Chime Vol, SOC digits IMG_0881
Af
The download finished last night. Two failures since then. Will drive to lunch and reset the BMS again.
And after about 8 failures and 2 or 3 days - it installed today. Gasp - the truck wasn't even locked !!! So truly - there are no consistent known requirements on what it takes to get these to install other than you can know 12 v SOC has the big part to play and resetting the BMS for it is about the only thing to make it happen.
Whammy Bar
It's white because your knuckles turn white when you have to grab the wheel and save your truck from swerving into the vehicle next to you for no reason.
queuewho
Western PA
22 F150 Lightning Lariat SR
Kinda makes sense to me, only really bluecruise when it's hands free
